CPU and Memory High Usage
mramirez-t
Level 3
Level 3
Ran into this problem with a stack of 2 3850 switches.
*%OSAPI-4-CPU_OVERLOAD:Switch 2 R0/0: wcm: Warning! Task 6585 (wcm) is taking 143% (0% user 143%system)of the cpu!.
Nov 9 11:37:41.176: %PLATFORM-3-ELEMENT_CRITICAL:Switch 1 R0/0: smand: 2/RP/0: Used Memory value 100% exceeds critical level 95%
Nov 9 11:47:50.474: %PLATFORM-3-ELEMENT_CRITICAL:Switch 1 R0/0: smand: 2/RP/0: Used Memory value 100% exceeds critical level 95%
Nov 9 11:58:00.550: %PLATFORM-3-ELEMENT_CRITICAL:Switch 1 R0/0: smand: 2/RP/0: Used Memory value 100% exceeds critical level 95%
Nov 9 12:08:03.159: %PLATFORM-3-ELEMENT_CRITICAL:Switch 1 R0/0: smand: 2/RP/0: Used Memory value 100% exceeds critical level 95%
It caused switch 1 to drop from the stack and anything connected to it lost network communication.  Switch 1 came back but I dont have any scheduled tasks running on the switch, so I'm not sure what's cuasing this.  Any help is appreciated.
5 Replies 5
Reza Sharifi
Most likely an IOS bug.  You should open a ticket with TAC and send them the info.  Most of the time they will recommend an upgrade.
Leo Laohoo
What version is the stack running on?
mramirez-t
Level 3
Level 3
It's version 16.3.1.  We opened a ticket with our MSP on it and sent them a 'show tech' output.
Roll back to 3.6.X. IOS-XE for switches is notorious for memory leak across the entire IOS range. 3.6.X, for Reza, or 3.7.X is least affected by this.
I can't speak for the 3.6.x train, but from my experience, the 3.7.x train is garbage. We had constant bugs with 3.7.1 and 3.7.3, until we moved to Denali 16.3.5b.
