VTP vlans not loading after reloading
haydenhicks97
Community Member
Hello people,
When i reload my switches the vlans from the VTP server are no longer on the clients, but before i reload they are there, and i have to open the vlans again and redo the VTP commands? is this a bug?
5 Replies 5
Hulk8647
Level 5
Level 5
so your VTP config is also gone from the switches?
Yes, when issuing the show run, vtp is not displayed even when its working
can you post the whole output of show version?
ALS1#show version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 11:39 by nachen
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
ALS1 uptime is 13 minutes
System image file is "flash:/c2960-lanbase-mz.122-46.SE.bin"
cisco WS-C2960-24TT-L (PowerPC405) processor (revision P0) with 61440K/4088K bytes of memory.
Processor board ID FCQ1616Y4G9
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : A4:18:75:B5:F5:80
Motherboard assembly number : 73-11473-11
Power supply part number : 341-0097-03
Motherboard serial number : FCQ16150J1P
Power supply serial number : DCA15148K6G
Model revision number : P0
Motherboard revision number : A0
Model number : WS-C2960-24TT-L
System serial number : FCQ1616Y4G9
Top Assembly Part Number : 800-29859-06
Top Assembly Revision Number : C0
Version ID : V10
CLEI Code Number : COMCX00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT-L 12.2(46)SE C2960-LANBASE-M
Configuration register is 0xF
Georg Pauwen
which switches do you have, and what IOS version are you running ?
Post the output of 'show vtp status' from te=he server and one of the client switches...
