cpu clock speed on a 3750x switch?
StevenJester
Hi all,
        Does any one know how to find the CPU speed?
InayathUlla Sharieff
there is no way you can findout the CpU speed.
Systems proprietary information, which includes CPU speed, make or any other
architecture information that is requested as part of the requirement.
just need to make sure you check the switches performance if you are comparing with any other model.
hth
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Not easily, if not listed in any Cisco show command.  But, I'm curious why you want to know.  On L3 switches, performance/capacity is determined by the rest of the "hardware", i.e. it's much, much more than CPU clock rate.  Generally, on something like a 3750, CPU is just used for high level control plane functions.
I will note, years ago while testing RIP processing performance, a 2811 seemed much faster than an original 3750 although the latter had much, much, much more forwarding performance.
