Minor Error on Sup720
Boyan Sotirov
Has anyone came across this?
Online Diagnostic of Supervisor Engine 720 (Hot): Test 35, Error code 43 (DIAG_CHECK_ETHER_PAK_ERROR)
The complete diagnostic level was enabled on the system:
#show diagnostic result module 6 failure detail
Current bootup diagnostic level: complete
Overall Diagnostic Result for Module 6 : MINOR ERROR
Diagnostic level at card bootup: complete
Test results: (. = Pass, F = Fail, U = Untested)
35) TestUnusedPortLoopback:
Port 1 2 3 4 5
U U F U F
Error code ------------------> 43 (DIAG_CHECK_ETHER_PAK_ERROR)
Total run count -------------> 2457255
Last test execution time ----> Sep 16 2014 10:14:59
First test failure time -----> Jun 13 2012 11:37:30
Last test failure time ------> Sep 16 2014 10:14:59
Last test pass time ---------> Jun 13 2012 11:36:23
Total failure count ---------> 717278
Consecutive failure count ---> 717278
#show module 6
Mod Ports Card Type Model Serial No.
6 5 Supervisor Engine 720 10GE (Hot) VS-S720-10G
Mod MAC addresses Hw Fw Sw Status
6 001d.45e2.0058 to 001d.45e2.005f 2.0 8.5(2) 12.2(33)SXH4 Ok
Mod Sub-Module Model Serial Hw Status
6 Policy Feature Card 3 VS-F6K-PFC3C  1.0 Ok
6 MSFC3 Daughterboard VS-F6K-MSFC3  1.0 Ok
Mod Online Diag Status
6 Minor Error
InayathUlla Sharieff
Hardware defect. RMA the module .
please go ahead and replace the module. In the mean time just give a try by reseating the same.
Inayath
********Plz dont forget to rate usefull posts******
