cpu usage
ilnaiduccna
Hi all,
I am having doubt about cpu usage below pasted can anybody explain.
1111111111111111111111111111111111111111111111111111111111
2277777777779999999999888888888877777333333333322222111112
100
90
80
70
60
50
40
30
20***********************************
10************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
1122221122112121111212112121121112112111121212222221112212
9900009922770819797080890805938271970899819091300119791070
100
90
80
70
60
50
40
30
20 *#####**##**#*#**#*#*#*#**#**#* *##*#****#*#*#######**##*###
10 #####################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
2242222332711111112222222222222332621111122223222222232332411111112222
6604664566495566993677546447566626846455613674644468616788454456792357
100
90
80
70 * *
60 * *
50 * *
40 * ** * * * ** *
30 *** ** **** **** * ******** **** ********* **
20 ########***********#############***** *****#####*#######**** *****####*
10 ###########*****###################*****##################*******#######
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Naidu.
glen.grant
Not sure what you are asking , one is the maximum * which could mean just a very brief spike which is nothing to worry about, doesn't mean it is the sustained usuage. # is the average , it looks like most of the time for the last 72 hours the cpu "average" is at least 20% but less than 30 with brief periods of less than 10% cpu usuage. Can't tell you more than that , you would have to look at the processes to see what is using what , as most traffic is hardware switched utilization on the cpu is usually taken up by other processes other than routing ip traffic.
