CPU utilization high on 3560
susim
Level 3
Level 3
Hi all ,
cpu spiking up to 90-100% , Does it solve the issue if we upgrade the firmware "c3560-ipservicesk9-mz.122-55.SE9" .
Current firmware is "flash:/c3560-ipbasek9-mz.122-55.SE7/c3560-ipbasek9-mz.122-55.SE7.bin"
CPU utilization for five seconds: 46%/27%; one minute: 57%; five minutes: 59%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 128   697586238 102711558       6791 12.13% 11.10%  9.46%   0 Hulc LED Process
sh version
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:10 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Sw2 uptime is 8 weeks, 1 day, 22 hours, 40 minutes
System restarted at 14:45:00 UTC Mon Nov 24 2014
System image file is "flash:/c3560-ipbasek9-mz.122-55.SE7/c3560-ipbasek9-mz.122-55.SE7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-48PS (PowerPC405) processor (revision P0) with 131072K bytes of memory.
Processor board ID FDO1228X1KA
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:22:56:C7:EF:80
Motherboard assembly number     : 73-9676-18
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO122807K5
Power supply serial number      : DTN122346E8
Model revision number           : P0
Motherboard revision number     : C0
Model number                    : WS-C3560-48PS-S
System serial number            : FDO1228X1KA
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : FDO12280149
Top Assembly Part Number        : 800-25859-08
Top Assembly Revision Number    : F0
Version ID                      : V09
CLEI Code Number                : COMU210ARA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560-48PS      12.2(55)SE7           C3560-IPBASEK9-M
Configuration register is 0xF
Thank you
7 Replies 7
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I doubt moving from 55SE7 to 55SE9 would make much if any difference, as 55SE7 is fairly solid, but it wouldn't hurt to try.
The high Hulc LED Process CPU, I believe, is a low priority task, so it's CPU consumption has little actual impact on switch processing.  What else is your CPU breakdown?  For example, in what you've posted, the CPU is shows 59% over five minutes while the Hulc LED Process only shows about 10% over the same five minutes.  I.e. what's the other 50%?
Thanks Joesph
This time i have taken whole processes
w4#       Show proc cpu | exc 0.00%
CPU utilization for five seconds: 45%/25%; one minute: 47%; five minutes: 54%
PIDRuntime(ms)InvokeduSecs5Sec1Min5MinTTYProcess
33284849949673255730.15%0.04%0.02%0Per-Second Jobs
876749010603566201110.15%0.46%0.22%0hpm main process
9021725143496321443770.15%0.09%0.12%0hpm counter proc
128699401298103072096678511.66%11.01%11.15%0Hulc LED Process
1377734146100245677150.15%0.11%0.11%0HQM Stack Proces
184124646926560.31%0.04%0.10%1SSH Process
204809888081680504754811.75%1.21%1.37%0Spanning Tree
2373711424131840022810.15%0.13%0.10%0IGMPSN
Disclaimer
Posting
Hmm, well your total process CPU seems higher than the sum of that show for the tasks, and you have a good bit of interrupt CPU (which can be somewhat difficult to identify the cause).
But that and you spikes don't always imply you have a performance problem.  For example, here's some CPU history on two of my stacks (also running 55SE3 and 55SE6).
    1                     1 1         1           1           1
    0334333343933433393354040333353334033333343334033353433353033343333333
    0773556625997086699749000977736841098777718874069898067656087505786698
100 *         *      *    * *         *           *           *
 90 *         *      *    * *         *           *           *
 80 *         *      *    * *         *           *           *
 70 *         *      *    * *         *           *           *
 60 *         *      *    * *         *           *   *     * *
 50 *         *      *  *** *    *    *           *   *     * *
 40 ******************************** *************************************
 30 **********************************************************************
 20 ######################################################################
 10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
         1    1               1 1    1                  1    1
    4333303433033333394334334503033450333333933433333333033730363333933433
    2666505783075657792651461908076710637457232067577556055380506677876236
100      *    *      *        * *    *                  *    *      *
 90      *    *      *        * *    *      *           *    *      *
 80      *    *      *        * *    *      *           *    *      *
 70      *    *      *        * *    *      *           *  * *      *
 60      *    *      *       ** *    *      *           *  * * *    *
 50      * *  *      *       ** *  ***      *           *  * * *    *
 40 ********* ************ ************ * ***  ************************* *
Hi joesph
How did u come to know that there is lot of cpu interrupt
Actually there is a lot of multicast listener report message flooding the network from some HP pc’s . How can I protect the switch from the flood
Thank you
Disclaimer
Posting
"How did u come to know that there is lot of cpu interrupt"
It's the 2nd percentage value of the 5 second CPU usage stat.
In your case, about 25%, which wouldn't seem too high, and that might be fine, but as forwarding should be done by ASICs, one can wonder what this 25% is.
"Actually there is a lot of multicast listener report message flooding the network from some HP pc’s . How can I protect the switch from the flood"
Often there's different flood limiters you can enable.  However, you need to be very careful enabling them, as they can block needed "flood" traffic too.
I've posted some history stats from two of my, more busy, 3750 stacks, and as you can see they average about 20% and with peaks of 100%, so you might not have a CPU problem.  What does your 36 hour CPU status look like?
Hi joesph
I have attached last 72 hours history
Here is the whole process
128699369860103068265678510.70%10.95%11.32%0Hulc LED Process
204809860351680467714810.79%1.28%1.56%0Spanning Tree
3017329485536412213660.47%0.11%0.07%0SNMP ENGINE
2993182428108579612930.31%0.09%0.05%0IP SNMP
14814465144496567029130.15%0.14%0.15%0PI MATM Aging Pr
926253312987142020.15%0.02%0.00%0ARP Input
33284839049671345730.15%0.04%0.02%0Per-Second Jobs
5710674761232556471450.15%0.13%0.17%0Fifo Error Detec
702318715146599643150.15%0.02%0.00%0HLFM address lea
60200.00%0.00%0.00%0Timers
70100.00%0.00%0.00%0HRPC asic-stats
80100.00%0.00%0.00%0Crash writer
100100.00%0.00%0.00%0CEF MIB API
110100.00%0.00%0.00%0AAA_SERVER_DEADT
120200.00%0.00%0.00%0AAA high-capacit
130100.00%0.00%0.00%0Policy Manager
141503542850.00%0.00%0.00%0Entity MIB API
150100.00%0.00%0.00%0IFS Agent Manage
16174983683200.00%0.00%0.00%0IPC Dynamic Cach
170100.00%0.00%0.00%0IPC Zone Manager
182522294966651500.00%0.00%0.00%0IPC Periodic Tim
190100.00%0.00%0.00%0IPC Managed Time
202477434966642490.00%0.00%0.00%0IPC Deferred Por
216912334658200.00%0.00%0.00%0IPC Seat Manager
220100.00%0.00%0.00%0IPC Session Serv
23844210000.00%0.00%0.00%0PrstVbl
243486494966665700.00%0.00%0.00%0Dynamic ARP Insp
250100.00%0.00%0.00%0ARP Snoop
262491074966644500.00%0.00%0.00%0GraphIt
270200.00%0.00%0.00%0XML Proxy Client
280100.00%0.00%0.00%0Critical Bkgnd
29143665616622138640.00%0.01%0.00%0Net Background
300100.00%0.00%0.00%0IDB Work
31437886789500.00%0.00%0.00%0Logger
323306374966667660.00%0.00%0.00%0TTY Background
34276190984975325020.00%0.02%0.00%0Per-minute Jobs
350500.00%0.00%0.00%0IF-MGR control p
3671422449310.00%0.00%0.00%0IF-MGR event pro
3717629434236400.00%0.00%0.00%0Net Input
3870931810026987070.00%0.00%0.00%0Compute load avg
390100.00%0.00%0.00%0AggMgr Process
408705110.00%0.00%0.00%0Transport Port A
411104651502506730.00%0.00%0.00%0HC Counter Timer
420100.00%0.00%0.00%0SFF8472
432408139930478420.00%0.00%0.00%0DownWhenLooped
440100.00%0.00%0.00%0HULC PBR Tcam Me
450100.00%0.00%0.00%0HULC ACL Tcam Me
460100.00%0.00%0.00%0HRPC EnergyWise
470100.00%0.00%0.00%0HRPC actual powe
480100.00%0.00%0.00%0HRPC lpip reques
490200.00%0.00%0.00%0HLPIP Sync Proce
500100.00%0.00%0.00%0HULC QM Tcam Mem
51352902049891720.00%0.00%0.00%0EEM ED ND
5204400.00%0.00%0.00%0EEM ED Identity
5304100.00%0.00%0.00%0EEM ED MAT
540100.00%0.00%0.00%0HRPC hsm request
550700.00%0.00%0.00%0Stack Mgr
562448305000.00%0.00%0.00%0Stack Mgr Notifi
58113545125160.00%0.00%0.00%0Adjust Regions
5962289949666911250.00%0.00%0.00%0hrpc -> response
60236271019407230.00%0.00%0.00%0hrpc -> request
6122647610295832190.00%0.00%0.00%0hrpc <- response
620100.00%0.00%0.00%0HRPC hcomp reque
630300.00%0.00%0.00%0HULC Device Mana
640300.00%0.00%0.00%0HRPC hdm non blo
650200.00%0.00%0.00%0HRPC hdm blockin
66316291002589310.00%0.00%0.00%0HIPC bkgrd proce
679550539981760.00%0.00%0.00%0Hulc Port-Securi
680100.00%0.00%0.00%0HRPC hpsecure re
690100.00%0.00%0.00%0HRPC hlfm reques
71128658249668072590.00%0.02%0.00%0HLFM aging proce
7276882414779279450.00%0.00%0.00%0HLFM address ret
730100.00%0.00%0.00%0HRPC hulc misc r
52564106824000.00%0.00%0.00%0Pool Manager
7515755167172090.00%0.00%0.00%0HVLAN main bkgrd
4719058963149112228330.00%1.08%1.02%0Check heaps
770200.00%0.00%0.00%0Vlan shutdown Pr
7813571541832500.00%0.00%0.00%0HRPC vlan reques
790200.00%0.00%0.00%0HULC VLAN REF Ba
800100.00%0.00%0.00%0HRPC hfbm reques
811872790660.00%0.00%0.00%0HCMP sync proces
820100.00%0.00%0.00%0HRPC ilp request
8333482500.00%0.00%0.00%0Inline Power Twt
8412429169947310.00%0.00%0.00%0HULC PM Vector P
850100.00%0.00%0.00%0HPM Msg Retry Pr
869412334656280.00%0.00%0.00%0MDFS LC Download
876747981603538831110.00%0.03%0.08%0hpm main process
88281438558720.00%0.00%0.00%0HPM Stack Sync P
890100.00%0.00%0.00%0HRPC pm request
9021724907496302343770.00%0.13%0.16%0hpm counter proc
910100.00%0.00%0.00%0HRPC pm-counters
920100.00%0.00%0.00%0hpm vp events ca
930100.00%0.00%0.00%0HRPC hcmp reques
94342394140.00%0.00%0.00%0HCEF ADJ Refresh
950100.00%0.00%0.00%0HRPC hl3mm reque
960100.00%0.00%0.00%0hl3md_rpfq_thrl_
97407313508912110.00%0.00%0.00%0hl3mm
9818894250318070.00%0.00%0.00%0hl3mm_rp
990100.00%0.00%0.00%0HACL Queue Proce
1000100.00%0.00%0.00%0HRPC acl request
1019127700.00%0.00%0.00%0HACL Acl Manager
30100.00%0.00%0.00%0Connection Mgr
103267842355711360.00%0.00%0.00%0SpanTree Helper
1040100.00%0.00%0.00%0HRPC cdp request
1050100.00%0.00%0.00%0HRPC lldp reques
1060100.00%0.00%0.00%0HULC CISP Proces
1070100.00%0.00%0.00%0HRPC dot1x reque
1080300.00%0.00%0.00%0HULC DOT1X Proce
1090100.00%0.00%0.00%0HRPC system mtu
1100100.00%0.00%0.00%0HRPC rep request
1110400.00%0.00%0.00%0REP Helper Proc
1120100.00%0.00%0.00%0SMI MSG Retry Pr
1130100.00%0.00%0.00%0HRPC Smart Insta
1140100.00%0.00%0.00%0HRPC sdm request
115113438024795324450.00%0.00%0.00%0Hulc Storm Contr
1160200.00%0.00%0.00%0HSTP Sync Proces
1170100.00%0.00%0.00%0HRPC stp_cli req
1180100.00%0.00%0.00%0HRPC stp_state_s
1190200.00%0.00%0.00%0S/W Bridge Proce
1200100.00%0.00%0.00%0HRPC hudld reque
1210100.00%0.00%0.00%0HRPC vqpc reques
1220100.00%0.00%0.00%0HRPC iec_load_ba
1230100.00%0.00%0.00%0HRPC l2pt qnq rp
1240100.00%0.00%0.00%0HRPC aim request
1250200.00%0.00%0.00%0MACsec Process
1260100.00%0.00%0.00%0HRPC macsec requ
1270100.00%0.00%0.00%0HRPC hled reques
22977100300720.00%0.00%0.00%0Load Meter
1292043473670701550.00%0.00%0.00%0HL3U bkgrd proce
1300100.00%0.00%0.00%0HRPC hl3u reques
1319615114662480.00%0.00%0.00%0HL3U PBR bkgrd p
13255341854130.00%0.00%0.00%0HL3U PBR n-h res
1330100.00%0.00%0.00%0HRPC dtp request
1340100.00%0.00%0.00%0HRPC show_forwar
1350100.00%0.00%0.00%0HRPC snmp reques
1360100.00%0.00%0.00%0HULC SNMP Proces
1377733827100241877150.00%0.09%0.11%0HQM Stack Proces
138145801720048157270.00%0.00%0.00%0HRPC qos request
1390100.00%0.00%0.00%0HRPC span reques
1400100.00%0.00%0.00%0HRPC system post
1410100.00%0.00%0.00%0Hulc Reload Mana
1420100.00%0.00%0.00%0HRPC hrcli-event
14344743251100.00%0.00%0.00%0DHCPD Timer
1440200.00%0.00%0.00%0image mgr
14511132167171760.00%0.00%0.00%0Power RPS Proces
14616672380.00%0.00%0.00%0HL2MCM
74191841650172838230.00%0.01%0.00%0HULC Tcam Memory
760200.00%0.00%0.00%0HVLAN Mapped Vla
1490200.00%0.00%0.00%0REP Topology cha
1500200.00%0.00%0.00%0Switch Backup In
1020100.00%0.00%0.00%0HRPC backup inte
152151822681660.00%0.00%0.00%0Auth Manager
1530200.00%0.00%0.00%0Dot1x Mgr Proces
1540100.00%0.00%0.00%0MAB Framework
1550100.00%0.00%0.00%0AUTH POLICY Fram
1560100.00%0.00%0.00%0CMD HANDLER
1578137333482440.00%0.00%0.00%0802.1x switch
158173883684200.00%0.00%0.00%0802.1x MDA Aging
1590100.00%0.00%0.00%0802.1x Webauth F
160887175079901740.00%0.00%0.00%0DTP Protocol
1610100.00%0.00%0.00%0EAP Framework
1620100.00%0.00%0.00%0EAP Test
1630100.00%0.00%0.00%0HRPC dai request
1640100.00%0.00%0.00%0HULC DAI Process
1650100.00%0.00%0.00%0HRPC ip device t
1660100.00%0.00%0.00%0HRPC ip source g
1670100.00%0.00%0.00%0HULC IP Source g
16823033502306140.00%0.00%0.00%0UDLD
16944832418062624820.00%0.00%0.00%0Port-Security
1708240000.00%0.00%0.00%0IP Host Track Pr
1710100.00%0.00%0.00%0Link State Group
172467250184890.00%0.00%0.00%0Ethchnl
173220411647131330.00%0.00%0.00%0VMATM Callback
1740200.00%0.00%0.00%0CDP Forward Proc
1752829274972104150.00%0.00%0.00%0MDFS MFIB Proces
1760200.00%0.00%0.00%0MKA
177161141400.00%0.00%0.00%0AAA Server
17834359940.00%0.00%0.00%0AAA ACCT Proc
1790100.00%0.00%0.00%0ACCT Periodic Pr
1800100.00%0.00%0.00%0AAA System Acct
1810100.00%0.00%0.00%0Auth-proxy AAA B
182861674450.00%0.00%0.00%0IP Admin SM Proc
1831754340112971115520.00%0.00%0.00%0CDP Protocol
184100136927120.00%0.31%0.16%1SSH Process
1850100.00%0.00%0.00%0HRPC x_setup req
1860200.00%0.00%0.00%0AAA Dictionary R
1873964185990.00%0.00%0.00%0DHCP Snooping
1880100.00%0.00%0.00%0DHCP Snooping db
1890200.00%0.00%0.00%0EAPoUDP Process
1900300.00%0.00%0.00%0CEF switching ba
1911247822107885621150.00%0.04%0.00%0IP Input
1920100.00%0.00%0.00%0ICMP event handl
19359671969019260.00%0.00%0.00%0IP ARP Track
1940300.00%0.00%0.00%0ADJ resolve proc
1950200.00%0.00%0.00%0ADJ NSF process
1960100.00%0.00%0.00%0IPv6 ping proces
1980100.00%0.00%0.00%0SMI Director DB
1990100.00%0.00%0.00%0SMI CDP Update H
2000100.00%0.00%0.00%0SMI Backup Proce
2010200.00%0.00%0.00%0SMI IBC server p
2020100.00%0.00%0.00%0SMI IBC client p
2030200.00%0.00%0.00%0SMI IBC Download
14717356660.00%0.00%0.00%0HL2MCM
2052928371330.00%0.00%0.00%0Spanning Tree St
2060200.00%0.00%0.00%0KRB5 AAA
2079521730.00%0.00%0.00%0SXP CORE
208131711013351290.00%0.00%0.00%0CEF background p
2090100.00%0.00%0.00%0IP IRDP
2100100.00%0.00%0.00%0CEF RF HULC Conv
2110200.00%0.00%0.00%0XDR mcast
2125984501846110.00%0.00%0.00%0IP ACL XDR LC Ba
2139190000.00%0.00%0.00%0IPC LC Message H
2140100.00%0.00%0.00%0XDR RP Ping Back
2153514185680.00%0.00%0.00%0XDR RP backgroun
2160100.00%0.00%0.00%0XDR RP Test Back
2170300.00%0.00%0.00%0MDFS LC Process
2181674569360.00%0.00%0.00%0TCP Timer
219341482290.00%0.00%0.00%0TCP Protocols
2204804496296600.00%0.00%0.00%0Socket Timers
221751675040.00%0.00%0.00%0HTTP CORE
2221836278820.00%0.00%0.00%0Cluster L2
2237039501850140.00%0.00%0.00%0Cluster RARP
22423824711133330.00%0.00%0.00%0Cluster Base
2250100.00%0.00%0.00%0RARP Input
226131083688150.00%0.00%0.00%0DHCPD Database
2270200.00%0.00%0.00%0REP LSL Proc
2280200.00%0.00%0.00%0REP BPA/EPA Proc
2290100.00%0.00%0.00%0Critical Auth
2300200.00%0.00%0.00%0Dot1x Supplicant
2310200.00%0.00%0.00%0Dot1x Supplicant
2320200.00%0.00%0.00%0Dot1x Supplicant
2330100.00%0.00%0.00%0HRPC dhcp snoopi
2340400.00%0.00%0.00%0HULC DHCP Snoopi
2352163568437025640.00%0.00%0.00%0IGMPSN L2MCM
236480902907101650.00%0.00%0.00%0IGMPSN MRD
2373711189131832622810.00%0.07%0.08%0IGMPSN
238192877475779625450.00%0.00%0.00%0IGMPQR
2390300.00%0.00%0.00%0L2TRACE SERVER
24066422513581548900.00%0.00%0.00%0Inline Power
24110518855110394399520.00%0.05%0.09%0Marvell wk-a Pow
24227951843533310.00%0.00%0.00%0MLDSN L2MCM
2430100.00%0.00%0.00%0MRD
2440100.00%0.00%0.00%0MLD_SNOOP
245257488299259322590.00%0.02%0.00%0DHCPD Receive
2460200.00%0.00%0.00%0REP Switch Helpe
2470100.00%0.00%0.00%0IP RIB Update
2480100.00%0.00%0.00%0HRPC hl2mcm igmp
2494516014982782590.00%0.00%0.00%0MDFS RP process
2500100.00%0.00%0.00%0HRPC hl2mcm mlds
2520100.00%0.00%0.00%0EPM MAIN PROCESS
2530200.00%0.00%0.00%0LOCAL AAA
2540200.00%0.00%0.00%0ENABLE AAA
2550200.00%0.00%0.00%0LINE AAA
2573577227715700.00%0.00%0.00%0TPLUS
2588126660.00%0.00%0.00%0crypto engine pr
25934485000.00%0.00%0.00%0Crypto CA
2600100.00%0.00%0.00%0Crypto PKI-CRL
2610100.00%0.00%0.00%0Crypto SSL
2620100.00%0.00%0.00%0encrypt proc
2638115690.00%0.00%0.00%0VTP Trap Process
2640200.00%0.00%0.00%0VTPMIB EDIT BUFF
2650200.00%0.00%0.00%0DHCP Security He
2660100.00%0.00%0.00%0HCD Process
2670100.00%0.00%0.00%0HRPC cable diagn
2680200.00%0.00%0.00%0DiagCard1/-1
26931524228983955100.00%0.00%0.00%0PM Callback
27083064133403472480.00%0.02%0.00%0VLAN Manager
272322140156680.00%0.00%0.00%0dhcp snooping sw
2730200.00%0.00%0.00%0EEM ED Routing
274437749413880.00%0.00%0.00%0EEM ED Syslog
276741146490.00%0.00%0.00%0AAA SEND STOP EV
27714979710345144800.00%0.00%0.00%0Syslog Traps
27822609464064870.00%0.00%0.00%0Syslog
27918902000.00%0.00%0.00%0EEM Server
2808240000.00%0.00%0.00%0EEM Policy Direc
2820200.00%0.00%0.00%0EEM ED CLI
2830300.00%0.00%0.00%0EEM ED Counter
2840300.00%0.00%0.00%0EEM ED Interface
2850300.00%0.00%0.00%0EEM ED IOSWD
2860300.00%0.00%0.00%0EEM ED None
2870300.00%0.00%0.00%0EEM ED OIR
288102627913670.00%0.00%0.00%0SSH Event handle
2890300.00%0.00%0.00%0EEM ED SNMP
2900300.00%0.00%0.00%0EEM ED SNMP Obje
2910300.00%0.00%0.00%0EEM ED Ipsla
2920200.00%0.00%0.00%0EEM ED SNMP Noti
2931987134974140.00%0.00%0.00%0EEM ED Timer
2940200.00%0.00%0.00%0STP FAST TRANSIT
2950200.00%0.00%0.00%0CSRT RAPID TRANS
2960300.00%0.00%0.00%0RBM CORE
29748067505961190.00%0.00%0.00%0NTP
29802100.00%0.00%0.00%0SNMP Timers
136223441540.00%0.00%0.00%0Chunk Manager
300165958253365693100.00%0.01%0.00%0PDU DISPATCHER
151119983683140.00%0.00%0.00%0MMN bkgrd proces
3020200.00%0.00%0.00%0IP SNMPV6
30314888507293640.00%0.00%0.00%0SNMP ConfCopyPro
3042896683436384290.00%0.00%0.00%0SNMP Traps
3053264077179962181370.00%0.00%0.00%0crypto sw pk pro
30602900.00%0.00%0.00%0hulc cfg mgr mas
307494492501977960.00%0.00%0.00%0hulc running con
