CPU utlization high
Rajesh-Jaisaram
Community Member
Quextion:- i have just see high cpu utliztion on WS-C3650-24PS switch, it's working on 03.06.03E ios virsion, is there any problem with this IOS
Mark Elsen
 - Use latest alternative software version for the platform , which is more productive and optimal then searching for bus>
    You can also have a  look at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Can you issue the command:
show process cpu sorted
This should show a list of processes the CPU is handling sorted by highest to lowest. This should show you why your CPU is showing high utilization.
-David
Leo Laohoo
Post the complete output to the following command when the CPU is "high":
sh proc cpu sort | exclude 0.00
