cpu1 and cpu2 usage in stack switch
csco11579831
Level 3
Level 3
2 Accepted Solutions
Ankur Arora
Level 7
Level 7
I am not sure how to check that using SNMP walk.
But following is the way to check it using switch CLI.
For example, you have a stack of 3 switches. Switch 1 is the master.
So when you do a Show proc cpu sort, you check the CPU of the master i.e. Switch 1 in this case.
Now in order to check the CPU of member switches 2,3 you have to do the following:
#session 2 (this will login you into the second switch of the stack)
#show proc cpu sort (this will tell you the cpu of the second switch
#exit
Similarly for the 3rd switch of the stack:
#session 3
#show proc cpu sort
Ankur
"Please rate the post if found useful"
The reason you are getting the error Command authorization failed. is because your user access doesn't have enough privilages to run this command. You might have a tacacs configured on the switch with a lower privilage level for your account.
Ankur
Ankur Arora
Level 7
Level 7
#exit
#session 3
#show proc cpu sort
Ankur
beslown the result:
BBO#session ?
  <1-9>  Switch number
BBO#session 2
i try this,but does not working
BBO#session 2 ?
  processor  destination processor for session
Ankur
OK,thanks for reply!
