crc error
prashantdwivedi
Community Member
i have couple of doubt...
1..what is crc error in router?
2..if switch drop the packet what could be the reason?
3.if we access www.google.com then what is source and destination ip address...i just took google for a example.
4.what is ingress and egrees buffer memory for 3750/3760 switches?
Phillip Remaker
1) CRC: Cyclic Redunancy Check, usually indicates a layer 1 problem, bits being corrupted in transit.  Every packet sent has a checksum that is computed by the transmitter.  If the checksum calculation does not match at the receiver, bits must have been corrupted so the packets are discarded.
2) A switch will drop a packet if it is corrupted, if there is no buffer space to receive the packet, or if any number of other error conditions occur
3) A switch will (generally) pick the primary address of the interface closest to the destination address for traffic originating from the switch.
4) Buffer memory is not a simple answer, see http://www.netcontractor.pl/blog/?p=538
What is the underlying problem?
crc errors also occur if half duplex and full duplex
mismatch
2. if cable is faulty and also in case of lan card is not functioning properly
kindly rate the post if info. is helpful
Rajat
