Create new Vlan on 3750 switch with trunk mode
Hi Team,
This is regarding VLAN creation on C3750E switch.
I want to create new Vlan 94 on this switch and also I want to allowed same interfaces like Vlan 95 & Vlan 96.
Please let me know how to allowed below interfaces on new Vlan 94 ???
switch#sh vlan id 95
VLAN Name                             Status    Ports
950  ASR1                             active    Gi1/0/3, Gi2/0/3, Po3, Po4, Po5
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
950  enet  100950     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
switch#sh vlan id 96
952  ASR2                             active    Gi1/0/3, Gi2/0/3, Po3, Po4, Po5
952  enet  100952     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
switch#
switch#sh run int Gi2/0/3
Building configuration...
Current configuration : 182 bytes
interface GigabitEthernet2/0/3
description Connection to Liberty-ASR-2 Gigabit0/1/1
switchport mode trunk
channel-group 2 mode active
end
switch#sh run int po3
Current configuration : 129 bytes
interface Port-channel3
description Channel to Liberty ASR1
end
switch#
3 Accepted Solutions
ALIAOF_
Level 6
Level 6
Well from what I can understand you want to create a VLAN 94, and looks like you already have created it.  Now you want to assign that VLAN to the two switch ports.  Those two switch ports are setup as a trunk, so all VLAN's should pass through them.
Whenever I login to this router, once go in keep on showing error logs, I don't know how to stop it....,
conf t
  no logging console
end
Hi Senthil,
What error message are you seeing?
Are you login to the console or you are telneting to the device?
If you want to completly stops all logs view  and if you are using console try issue "no logging console" and if it telnet/ssh access issue "terminal no monitor"
Najaf
Please rate when applicable or helpful !!!
7 Replies 7
ALIAOF_
Level 6
Level 6
Thanks for your reply, I have one more question with this asr 1002 router.... Whenever I login to this router, once go in keep on showing error logs, I don't know how to stop it....,
conf t
  no logging console
end
Hi Senthil,
Najaf
Hi Thanks for update....
Still we are getting same logs on c3750 switch....
Please check and let me how to stop it(sep error logs)
The bellows are option...
#no logging ?
  Hostname or A.B.C.D  IP address of the logging host
  buffered             Set buffered logging parameters
  buginf               Enable buginf logging for debugging
  cns-events           Set CNS Event logging level
  console              Set console logging parameters
  count                Count every log message and timestamp last occurance
  delimiter            Append delimiter to syslog messages
  discriminator        Create or modify a message discriminator
  esm                  Set ESM filter restrictions
  exception            Limit size of exception flush output
  facility             Facility parameter for syslog messages
  file                 Set logging file parameters
  filter               Specify logging filter
  history              Configure syslog history table
  host                 Set syslog server IP address and parameters
  message-counter      Configure log message to include certain counter value
  monitor              Set terminal line (monitor) logging parameters
  on                   Enable logging to all enabled destinations
  origin-id            Add origin ID to syslog messages
  queue-limit          Set logger message queue size
  rate-limit           Set messages per second limit
  reload               Set reload logging level
  source-interface     Specify interface for source address in logging
--More--
Thanks....
The issue has been resolved...
Sen
