Create RSTP in Cisco-3750
santosh.y
I have two Cisco-3750 Switches and i want to enable RSTP only two Ports. But i m not able to cofigure ? Please suggest me anybody.
Shashank Singh
Hi Santosh,
Spanning tree is a global configuration and cannot be enabled/disabled per port. To enable RPVST globally, configure the following:
Switch(config)#spanning-tree mode rapid-pvst
Once you enable rpvst, there will be one spanning tree instance for each vlan acting on all the ports in up/up state.
Hope that helps,
Shashank
P.S. Please rate helpful post.
