interface reset
krjohnson
Community Member
I have an ISR with and interface that shows up as follows;
GigabitEthernet0/0 is reset, line protocol is down
I cannot get rid of the 'reset' state... actually I'm not quite sure what 'g0/0 is reset' really means, I don't recall having ever seen this statement before. Can someone enlighten me?
thanks
kj
Shashank Singh
The interface status is incorrectly displayed as reset. This is due to an internal cosmetic bug which has been fixed in IOS version 15.0(1)M4 and later.
Cheers,
Shashank
P.S. Please rate if this helped answer your question.
Please find the below will help you.
Serial x is down, line protocol is down This status indicates that the router is not sensing a carrier detect (CD) signal.
Possible Causes:
  1. Telephone company problem.
  2. Faulty or incorrect cabling
  3. Hardware failure
Suggested Actions:
  1. Check the LED's on the CSU/DSU to see if the CD light is active.
  2. Verify that the cables are connected properly.
  3. Reset your equipment
  4. Contact your leased-line provider
  5. Replace faulty equipment
Please rate the helpfull posts.
Naidu.
