Creating a dot1q trunk on a 7200
frank.murray
okay...I must be loosing my mind. I'm trying to configure a fastethernet interface on a 7200 to be a 802.1q trunk to a Cisco 4000 switch.
I created the subinterface:
fastethernet 0/0.1
but in the subinterface config there's no encapsulation command.
What am I missing here?
Jon Marshall
Hi Frank
The 7200 does support 802.1q so it is probably the feature set that you are missing. You need a minimum of IP Plus to support 802.1q encapsulation.
Jon
ankbhasi
Hi Frank,
I hope you are not running IP BASE feature set image. You need minimum IP PLUS to support encapsulation command.
Ankur
ajagadee
This could be an issue with the code that you are running on the 7200. If I remember correctly, you need a minimum of IP Plus feature set to do 802.1q encapsulation.
Arul
