Creating an Trunk between Cisco 2960 to Two HP procurve 2610
garry1024
please help me.
I have two HP 2610 with following configuration.
; J9085A Configuration Editor; Created on release #R.11.25
hostname "Switch B"
snmp-server contact "Infa Systems Ltd"
snmp-server location "HKC"
time timezone 8
interface 25
   flow-control
exit
interface 26
   flow-control
exit
interface 27
   flow-control
exit
interface 28
   flow-control
exit
trunk 25-28 Trk1 Trunk
ip default-gateway 192.168.0.1
snmp-server community "public" Unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-24,Trk1
   ip address 192.168.0.7 255.255.255.0
   exit
filter source-port "1" drop 2-24
filter source-port "2" drop 1,3-24
filter source-port "3" drop 1-2,4-24
filter source-port "4" drop 1-3,5-24
filter source-port "5" drop 1-4,6-24
filter source-port "6" drop 1-5,7-24
filter source-port "7" drop 1-6,8-24
filter source-port "8" drop 1-7,9-24
filter source-port "9" drop 1-8,10-24
filter source-port "10" drop 1-9,11-24
filter source-port "11" drop 1-10,12-24
filter source-port "12" drop 1-11,13-24
filter source-port "13" drop 1-12,14-24
filter source-port "14" drop 1-13,15-24
filter source-port "15" drop 1-14,16-24
filter source-port "16" drop 1-15,17-24
filter source-port "17" drop 1-16,18-24
filter source-port "18" drop 1-17,19-24
filter source-port "19" drop 1-18,20-24
filter source-port "20" drop 1-19,21-24
filter source-port "21" drop 1-20,22-24
filter source-port "22" drop 1-21,23-24
filter source-port "23" drop 1-22,24
filter source-port "24" drop 1-23
spanning-tree Trk1 priority 4
no autorun
and
hostname "Switch C"
time timezone 8
interface 25
   flow-control
exit
interface 26
   flow-control
exit
interface 27
   flow-control
exit
interface 28
   flow-control
exit
trunk 25-28 Trk2 Trunk
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-24,Trk1
   ip address 192.168.0.8 255.255.255.0
   exit
spanning-tree Trk2 priority 4
no autorun
I also have a broadband router 192.168.0.1 connected to Cisco 2960
I would appreciate if someone could please send me the config on the Cisco 2960
Thank You Very Much
Ankur Arora
What exactly you need in the 2960 config? Are you looking just the trunk config of the interfaces in 2960?
devils_advocate
Level 7
Level 7
If you want to bring up a trunk between a 2960 and the HP switch then the config on the Cisco would be:
#interface fa0/*
#switchport trunk encapsulation dot1q
#switchport mode trunk
Remember to create any Vlans (other than Vlan1) on the Cisco that you want to pass traffic for.
You also need to ensure that any Vlans (other than 1) are 'Tagged' on the HP switch for the Trunk port which connects to the Cisc.
