logging persistent on Catalyst Switches
does someone know how to configure "logging persistent" on Catalyst 2960-S switches?
I did it sucessfully on ISR G2 routers under IOS 15x, but on the Catalyst 2960S it seems to be not working,
although the command "logging" has the option "persistent":
switch(config)#logging persistent ?
  batch      Set batch size for writing to persistent storage
  filesize   Set size of individual log files
  immediate  Write log entry to storage immediately (no buffering).
  notify     Notify when show logging [persistent] is activated.
  protected  Eliminates manipulation on logging-persistent files.
  size       Set disk space for writing log messages
  threshold  Set threshold for logging persistent
  url        URL to store logging messages
  <cr>
switch(config)#logging persistent url ?
% Unrecognized command
fti-mow01-ssw01(config)#logging persistent
%No ":/syslog" installed
Heinz
arickenbach
Frequent Visitor
Frequent Visitor
Hi Heinz
This command is not supportet with 15.X.
Use the following command:
logging file flash:filename [max-file-size] [min-file-size] [severity-level-number | type]
It works in my environment with 15.0(2)SE5.
Andrin
