Creating Etherchannel on Catalyst 3550
saidfrh18
I have two 3550s to create  an EtherChannel. Can I use any ports on the switches for the above, must the ports be Gig ports? assigning ports fa 0/9 - 10 on switches for channel-group 1 doesn't work.
DSW1#sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES unset  administratively down down
FastEthernet0/1        unassigned      YES unset  down                  down
FastEthernet0/2        unassigned      YES unset  down                  down
FastEthernet0/3        unassigned      YES unset  down                  down
FastEthernet0/4        unassigned      YES unset  down                  down
FastEthernet0/5        unassigned      YES unset  down                  down
FastEthernet0/6        unassigned      YES unset  down                  down
FastEthernet0/7        unassigned      YES unset  down                  down
FastEthernet0/8        unassigned      YES unset  down                  down
FastEthernet0/9        unassigned      YES unset  down                  down
FastEthernet0/10       unassigned      YES unset  down                  down
FastEthernet0/11       unassigned      YES unset  down                  down
FastEthernet0/12       unassigned      YES unset  down                  down
FastEthernet0/13       unassigned      YES unset  down                  down
FastEthernet0/14       unassigned      YES unset  down                  down
FastEthernet0/15       unassigned      YES unset  down                  down
FastEthernet0/16       unassigned      YES unset  down                  down
FastEthernet0/17       unassigned      YES unset  down                  down
FastEthernet0/18       unassigned      YES unset  down                  down
FastEthernet0/19       unassigned      YES unset  down                  down
FastEthernet0/20       unassigned      YES unset  down                  down
FastEthernet0/21       unassigned      YES unset  down                  down
FastEthernet0/22       unassigned      YES unset  down                  down
FastEthernet0/23       unassigned      YES unset  down                  down
FastEthernet0/24       unassigned      YES unset  down                  down
GigabitEthernet0/1     unassigned      YES unset  down                  down
GigabitEthernet0/2     unassigned      YES unset  down                  down
Port-channel1          unassigned      YES unset  down                  down
DSW1#
DSW2#
6 Replies 6
saidfrh18
Neither 3550 switches like,
DSW2(config)#vtp domain name BCMSN.
DSW1(config)#vtp domain name BCMSN
% Invalid input detected at '^' marker.
DSW1(config)#vtp mode server
Setting device to VTP SERVER mode
How do you assign VTP domain name?
shine pothen
Level 3
Level 3
for configuring Etherchannel you can use any of the port GigabitEthernet or else fast ethernet port.
An EtherChannel consists of individual Fast Ethernet or Gigabit Ethernet links bundled into a single logical link,The EtherChannel provides full-duplex bandwidth up to 800 Mbps (Fast EtherChannel) or 8 Gbps (Gigabit EtherChannel) between your switch,Each EtherChannel can consist of up to eight compatibly configured Ethernet interfaces. All interfaces in each EtherChannel must be the same speed, and all must be configured as either Layer 2 or Layer 3 interfaces
If you need help in configuring the ports please us know.
Shine
kindly advise to set up Etherchannel on the 3550 switchs.  All ports have been given the no shut command
The following is the config on both 3550 switches.
interface range fa 0/9 - 10
channel-group 1 mode desirable
interface port-channel 1
switchport trunk encap dot1q
switchport mode trunk
vtp mode server
[doesn't like] domain name BCMSN
Thanks.
Hi Saidf,
Let me resummarize this:
SW(3550)=====F0/9 -10==========Port-channel1============F0/9-10===SW2(3550)
Things to be checked:
1- Make sure the layer 1 is up. (I.e the links F0/9-10 are up state on both the switches) only then you will be able to form the etherchannel.
2- Shut down the ports at SW1.
3- Create Port-Channel on both the ends
4- Map the Port-Channel to the Physical interface.
5- Bring back the physical ports( i.e unshut the ports.)
6- Issue show etherchannel summary. (give it a 1 min time to get synchrnize).
B) Changing the VTP domain.
3500-5(config)# vtp domain BCMSN  >>>>>> This is the command to change the domain. (You should not use the name keyword under the vtp domain)
Changing VTP domain name from server to BCMSN
Inayath
*Plz rate all usefull posts.
glen.grant
conf t
vtp domain XXX
vtp mode server
int port-channel 1
switchport
switchport encapsulation dot1q
switchport mode dynamic desirable
switchport trunk allowed vlan x
int range f0/9 -10
switchport
channel-group 1 mode desirable non-silient
