creating NAT fot static and dynamic - beginner
NandaK
VLAN 60: 10.20.213.64/28    excluded address : 10.20.213.65 - .69
VLAN 80: 10.20.210.0/23      excluded address : 10.20.210.1 - .15
VLAN 60 (HOST PC) : 10.20.213.66
VLAN 80 (HOST PC) : 10.20.210.2
Backbone network LAN C : 10.20.208.0/23
For static :
i am supposed to map the assigned private address of VM2 to 10.20.208.50
Configure the NAT inside network on G0/0 on R2
Configure the NAT outside network on interface G0/1 on R2
This is my command:
en
config t
ip nat inside source static 10.20.213.66 10.20.208.50
end
config t
int g0/0
ip nat inside
int g0/1
ip nat outside
end
For Dynamic :
i am supposed to create standard acl 2 to allow ip address of pc 2 to do NAT translation.
Create a a public pool of ip address from <lan c network address> .80 to .90
Name it as Earpool and map acl 2 to it for NAT translation
Configure NAT inside network on the appropriate sub-interface on g0/0 on R2
Configure NAT outside network on interface g0/1 on R2
This is my command : en
config t
access-list 2 permit 10.20.213.64 0.0.0.15
ip nat pool Earpool 10.20.208.80 10.20.208.90 netmask 255.255.254.0
ip nat inside source list 2 pool Earpool
int g0/0.50
ip nat inside
int g0/0.60
ip nat inside
int g0/1
ip nat outside
end
What i am supposed to achieve FOR STATIC is : A host in public (VLAN 80) is able to access the web server VM2 using public static ip 10.20.208.50
What i am supposed to achieve FOR DYNAMIC is : Open a browser in PC2, enter pc 1 or vm1 ip address in the URL.
FYI: My pc is in DHCP so the ip address is 10.20.213.70
My vm2 is in static so the ip address is 10.20.213.66
Please advice if my command is wrong OR my settings is wrong.
Both not working and yes i have it all configured.
what exactly is not working ? Post the full configurations of your routers. I don't see any routes, do you have these configured ?
