DHCP not working properly - delays up to 5 min
jayage
Hi guys,
I noticed the following strange thing on different layer 3 switches. The client requests an IP address but the switch is trying to relay it instead of sending ack. We're using 3750s mainly, one acting as the dhcp with routing activated. It passes the traffic to its vpn box for all its vlans. We're using vlan 2 for our windows clients in general. Wired clients are quite fast with dhcp but the ones connecting through a wireless access point are taking up to 5 minutes until they receive their IP. The access points running flexconnect which drops all SSIDs into that vlan 2. Authentication is fast, it waits for IP when doing dhcp.
There is no relay configured on the SVI where the request came in:
interface Vlan2
 ip address 10.36.94.120 255.255.255.128
end
The dhcp is set up like this:
ip dhcp pool VLAN2
 network 10.36.94.0 255.255.255.128
 dns-server 10.36.1.1 10.36.1.2
 domain-name we-group.com
 default-router 10.36.94.120
 lease 0 12
The AP ports look like this:
interface FastEthernet0/12
 description WLAN AP
 switchport access vlan 2
 switchport mode access
 switchport nonegotiate
 authentication host-mode multi-host
 authentication port-control auto
 dot1x pae authenticator
 spanning-tree portfast
 spanning-tree bpduguard enable
When activating dhcp server debuggin for events and packets I can see the following section recurring:
Nov 29 16:25:59.686: DHCPD: Reload workspace interface Vlan2 tableid 0.
Nov 29 16:25:59.686: DHCPD: tableid for 10.36.94.120 on Vlan2 is 0
Nov 29 16:25:59.686: DHCPD: client's VPN is .
Nov 29 16:25:59.686: DHCPD: DHCPREQUEST received from client 01e0.ca94.7ee3.da.
Nov 29 16:25:59.686: DHCPD: Finding a relay for client 01e0.ca94.7ee3.da on interface Vlan2.
Nov 29 16:26:17.277: DHCPD: Reload workspace interface Vlan2 tableid 0.
Nov 29 16:26:17.277: DHCPD: tableid for 10.36.94.120 on Vlan2 is 0
Nov 29 16:26:17.277: DHCPD: client's VPN is .
Nov 29 16:26:17.277: DHCPD: DHCPREQUEST received from client 01e0.ca94.7ee3.da.
Nov 29 16:26:17.277: DHCPD: Finding a relay for client 01e0.ca94.7ee3.da on interface Vlan2.
Nov 29 16:26:26.698: DHCPD: Reload workspace interface Vlan2 tableid 0.
Nov 29 16:26:26.698: DHCPD: tableid for 10.36.94.120 on Vlan2 is 0
Nov 29 16:26:26.698: DHCPD: client's VPN is .
Nov 29 16:26:26.698: DHCPD: DHCPREQUEST received from client 01e0.ca94.7ee3.da.
Nov 29 16:26:26.698: DHCPD: Finding a relay for client 01e0.ca94.7ee3.da on interface Vlan2.
I am wondering why it looks for a relay? The switch runs dhcp and receives the request on its vlan..
Is this normal behavior?
Then after a while it finally got one:
Nov 29 16:27:58.478: DHCPD: Reload workspace interface Vlan2 tableid 0.
Nov 29 16:27:58.478: DHCPD: tableid for 10.36.94.120 on Vlan2 is 0
Nov 29 16:27:58.478: DHCPD: client's VPN is .
Nov 29 16:27:58.478: DHCPD: DHCPREQUEST received from client 01e0.ca94.7ee3.da.
Nov 29 16:27:58.478: DHCPD: Sending notification of ASSIGNMENT:
Nov 29 16:27:58.478:  DHCPD: address 10.36.94.40 mask 255.255.255.128
Nov 29 16:27:58.478:   DHCPD: htype 1 chaddr e0ca.947e.e3da
Nov 29 16:27:58.478:   DHCPD: lease time remaining (secs) = 43200
Nov 29 16:27:58.478:   DHCPD: interface = Vlan2
Nov 29 16:27:58.478:   DHCPD: out_vlan_id 0
Any idea what could cause the huge delay until our clients receive an IP?
10 Replies 10
Mark Elsen
 - Make sure that the DHCP server is intended to operate in the same VRF as the client network; this thread my be usefull :
   https://supportforums.cisco.com/discussion/11649636/dhcp-server-vrf
M,
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It resides in the same subnet/vlan and we're not using vrf.
Any further idea?
Still need help on this. Can please someone assist? Some clients do net get any IP address when connecting through the AP. The SSID is locally switched (flexconnect). VLAN2, where the SVI resides. DHCP server is wokring without issue when clients connect by cable.. Any idea on this?
Try to use this command, if you detect the leasing is exceeding the configured time:
ip dhcp binding cleanup interval <seconds>
Also verify if the device needs an upgrade of IOS.
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Do you have DHCP relay configured on WLC? If you do, play also with option 82 to see if it will make difference.
And IP DHCP relay on WLC should point to your DHCP server IP (switch IP).
We do not use dhcp relaying for the SSID having the issue.
Try using it. I had similar issues for guest SSID when ASA was used as DHCP... For some reason, it works better when WLC is proxy-ing DHCP than through broadcast...
Scope it not out of addresses so it won't help me on this. Leases get cleaned up properly. Switches run 150-2.SE6 or SE10 in different locations having the same issue. APs using LWAPP image 8.0.140.0 (we cannot upgrade yet as we still have some 1242s). As it works with same hardware/versions in some locations without having issues i don't think it is related to IOS.
crisantica
Your problem is in the AP switch port configuration. You said that the APs are in FlexConnect Mode. When the AP is in this mode, you need to put the AP port as Trunk and the administration Vlan as native.
Oron Yaniv
did you resolved your issue?
