creating sub interface with 3750G switch
a.rooprao
Hi I would like to create subinterfaces with 3750g series switch. pls let me know the IOS version supporting the same feature.
a.rooprao
Pls help.....
is there any alternate command to create sub interfaces with gig ports as it does not supports the command " int gig1/0/1.1 "
Hi roop,
enter the fallowing commands hope it will be clear you,
Switch-01#conf t
Switch-01#int GE0/1/2
Switch-01#description ******aaaaaaa******
Switch-01#switchport trunk encapsulation dot1q
Switch-01#switchport mode trunk
Naidu :-)
jorgenolla
I don't think the 3750 support subinterfaces as per command:
int gi1/0/1.1
You would usually communicate with subinterfaces on a router with a trunk port and specific vlans for each broadcast domain. Otherwise known as Router-On-A-Stick.
Best Regards
jorgenolla
Got some more information from the configuration guide, that confirms my suspicion.
From the configuration guide:
"A routed port behaves like a regular router interface, except that it does not support VLAN subinterfaces."
Here is the link for the configuration guide:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12244se/scg/swint.htm#wp1810955
Again your solution is Router-On-A-Stick, for inter-vlan communication, or SVIs.
Best Regards
