Cross stack etherchannel with LACP issue
grapevine
Level 5
Level 5
I have 2 cisco stacks with 2 switches of IE-9320-26S2C each with firmware 17.12.04. We have etherchannel configured between the two switches with the physical interfaces from each members on the stack.
When we power off one of the switches in the stack, we lose connectivity to the stack, how to fix it.
Configuration of switch 1 interfaces:
01# sh run int Po5
Building configuration...
Current configuration : 135 bytes
interface Port-channel5
description Uplink_to_Cluster2
switchport trunk allowed vlan 6,128,130,132,136
switchport mode trunk
end
01#sh run int Gi1/0/28
Current configuration : 197 bytes
interface GigabitEthernet1/0/28
description RSW01 28 / CLUSTER 2 SW5P28
channel-group 5 mode active
lacp rate fast
end
01#sh run int Gi2/0/28
interface GigabitEthernet2/0/28
description RSW02 28 / CLUSTER 2 SW6P28
lacp rate fast
end
Switch 2 config
2# sh run int Po5
description Uplink_to_Cluster1
end
2#sh run int Gi1/0/28
description RSW05 28 / CLUSTER 1 SW1P28
lacp rate fast
end
2#sh run int Gi2/0/28
description RSW06 28 / CLUSTER 1 SW2P28
lacp rate fast
end
grapevine
Level 5
Level 5
We fixed the issue by removing the command 'lacp rate fast'. Thanks for your assistance
@grapevine hi, do you have any logs when you disconnecting the cable? also is that disconnection happening only for few seconds or till connectivity restore totally?
Good luck
KB
when we power off the active member, the port in the member switch goes to suspended state and we lose connectivity
we applied stack-mac persistent timer 0 and still see the same issue
grapevine
Level 5
Level 5
