Crypto Key Generation
swesley2008
Community Member
Setting up a new 3750-X, do not want a crypto rsa keys configured. I do have ip http secure-server enabled and I believe this is whats causing these to keep generating.
I deleted the crypto pki trustpoint & certificate. I also did a 'crypto key zeroize rsa TP-self-signed'
I reload the switch and the keys are generated again. How do I disable these?
glen.grant
   If you have  https configured that is what is generating that key info you are seeing in the config .  The only way to get rid of it is to shut off http secure server  and reload the switch.
5 Replies 5
Latchum Naidu
You can use the ‘crypto key zeroize rsa’ command.
ITKE-AS1(config)#crypto key zeroize rsa
% All RSA keys will be removed.
% All router certs issued using these keys will
will also be removed.
Do you really want to remove these keys? [yes/no]: yes
Please click on the correct answer if this answered you question.
Naidu.
Yes I did that, and it was added again after reload.
That is what I did when I face the same proble.
So in your case you may need to upgrade your IOS as it seems like IOS bug with your current version.
Naidu.
glen.grant
Yeah thats what I ended up doing. Just disabling http secure-server, we don't need it anyway. Thanks!
