csma/ca
jonk34567
Level 6
Level 6
1 half-duplex systems
2 Full-duplex systems
3 Wireless system
what collison avoidance mechanism are they using ? csma/cd  oe csma/ca
DaSt-1986
Level 2
Level 2
Half duplex uses CSMA/CD
Full duplex doesn't use any collision avoidance or detection mechanism
Wireless uses CSMA/CA
syrehan
Level 2
Level 2
1. CSMA/CD is utilized in half-duplex systems to avoid collisions.
2. Full duplex systems don't need CSMA/CD because data can be sent and received at the same time by the communicating entities.
3. Wireless systems utilize CSMA/CA unlike CSMA/CD.
You can read about both CSMA/CD and CSMA/CA by following the below mentioned URLs:
https://en.wikipedia.org/wiki/Carrier-sense_multiple_access_with_collision_detection
https://en.wikipedia.org/wiki/Carrier-sense_multiple_access_with_collision_avoidance
I would however recommend you to keep the CCNA course book with you at all times. It helps a lot for references.
Hope to help!
Joseph W. Doherty
As the other posters have already noted, you wouldn't have collisions on full-duplex, so you don't need a CD or CA protocol. However, on some full-duplex systems there are protocols to indicate congestion, such as Ethernet full-duplex flow control.
