Multimode fiber loop
m.alshaweesh@extensya.com
Frequent Visitor
Frequent Visitor
Hi all,
i have Cisco core 4507 with Ten GB interface , i want to connect this interface with Multi mode fiber connection to an edge switch that have 1GB interface , both interface are up but there is no connectivity  between two switches , when execute  the show spanning tree the results
shows that the port are is BLK state:
sh spanning-tree vlan 205
VLAN0205
Spanning tree enabled protocol rstp
Root ID Priority 32973
Address 5897.1e07.2680
Cost 19
Port 10 (GigabitEthernet1/10)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32973 (priority 32768 sys-id-ext 205)
Address 70db.987c.ba80
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Te3/1 Back BLK 4 128.257 P2p
13 Replies 13
chrihussey
Can you post the interface configs and the interface status for both?
Ext-Amm-Core#show running-config interface tenGigabitEthernet 3/1
Building configuration...
Current configuration : 107 bytes
interface TenGigabitEthernet3/1
switchport trunk allowed vlan 205
switchport mode trunk
end
Ext-Amm-Core#show interfaces tenGigabitEthernet 3/1
TenGigabitEthernet3/1 is administratively down, line protocol is down (disabled)
Hardware is Ten Gigabit Ethernet Port, address is 70db.987c.ba80 (bia 70db.987c.ba80)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Last input 00:42:35, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
831 packets input, 203230 bytes, 0 no buffer
Received 829 broadcasts (829 multicasts)
831 packets output, 203230 bytes, 0 underruns
0 output errors, 0 collisions, 7 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
The interface is shutdown, it needs to be enabled.
int te3/1
no shut
If that doesn't work, can you post the output of "show mod"
Ext-Amm-Core#show mod
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT2127L0YF
2 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT2127L6SY
3 4 Sup 8L-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8L-E CAT2128L74N
4 4 Sup 8L-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8L-E CAT2128L6XQ
M MAC addresses Hw Fw Sw Status
1 3890.a505.e834 to 3890.a505.e863 1.1 Ok
2 500f.8030.beb0 to 500f.8030.bedf 1.1 Ok
3 70db.987c.ba80 to 70db.987c.ba83 1.0 15.1(1r)SG6 03.09.00.E Ok
4 70db.987c.ba84 to 70db.987c.ba87 1.0 15.1(1r)SG6 03.09.00.E Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Standby hot
is there any configuration for STP in case of fiber connection ??
Don't think it is a spanning tree issue.
Did you do a no shut, and can you configured "speed 1000" on the interface?
Then post the output of "show interface" for both interfaces
Ext-Amm-Core#sh int t3/1
TenGigabitEthernet3/1 is up, line protocol is
TenGigabitEthernet3/1 is up, line protocol is up (connected)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
Last input 00:00:00, output never, output hang never
836 packets input, 203605 bytes, 0 no buffer
Received 833 broadcasts (833 multicasts)
836 packets output, 203605 bytes, 0 underruns
0 output errors, 0 collisions, 8 interface resets
Ext-Amm-Core#show spanning-tree vlan 205
VLAN0205
Cost 19
Aging Time 300 sec
Gi1/10 Root FWD 19 128.10 P2p
Gi1/35 Desg FWD 4 128.35 P2p
the image for edge switch ad the show command is for core switch
So it looks as if there is a loop in your network and the t3/1 is a backup port. See the link below:
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/24062-146.html
You need to take a closer look at VLAN 205 and find the other path back to the root.
Hope this makes sense and helps
there is no loop put because fiber has two path one for TX and the other one for RX this is the cause of blocking  this port
That should not be the case. Recommend going to the edge switch and do the same "sh spanning-tree vlan 205" and see what the root port is on that switch.
edge switch is not live for now and just have one fiber cable on int g1/0/49 (trunk)
Please post the config of the edge switch and the output of "sh cdp nei"
