We are having CSS11500 load balancer used to monitor services on two servers on one particular application port.
We are using following configuration to moniter these services on these two servers.
ip addrss Server_IP_Adress
Port Port_Number_tobe_Monitored
keepalive type tcp
keeplaive port ****
max-failure 3
acive.
When we are using this service to moniter the application on the server after some time that application stops listening to that port automatically !!
We stopped monitering this application port and then that application servive starts running and the service keeps on running.
This is really surprising , that how service on server stops due to load balancer keepalives.
What type of keepalive messages are used by CSS11500 to check that the service is running on that port on that server.
If this is not working then in that case we will not be able to moniter the service of that particular application port service and load balaning will not take place.
Any idea why server service is stopping when CSS is used to moniter it.
Or it is aproblem related with Server.
IBM-AIX. is OS on the server.
Thanx in advance
subodh
