Ctrl + Break sequence not working
stevec90
I can not get the switch into rommon mode with the Ctrl + Break sequence, any suggestions? It's a 3512 switch. I just reset the password on another 3512 with no problem. ??
Ganesh Hariharan
Check out the below link for password recovery on cisco switches series
http://www-tss.cisco.com/eservice/compass/common/activities/password_cat_2950.htm
Ganesh.H
Ganesh Hariharan
Ganesh.H
Thanks, that did the trick. I guess the break key sequence was disabled on this switch? Something I'll have to look into -- I know the key sequence can be disabled on a router.
