CVR-QSFP-SFP10G WITH Nexus 7009
saeedek
Dear Gents,
i have CVR-QSFP-SFP10G(V02) installed on card N7K-F312FQ-25 inside Nexus switch 7009 .when i install 10G and 1 G sfp
it doesn't work
NX-OS 8(4).1
switch(config-if)# do sh int eth4/3
Ethernet4/3 is down (Transceiver validation failed)
if i removed sfp and keep CVR only inside line card
Ethernet4/1 is down (XCVR not inserted)
Ethernet4/1
    transceiver is present
    type is Unknown
    name is --
    part number is --
    revision is --
    serial number is --
    nominal bitrate is 0 MBit/sec per channel
    cisco id is --
    cisco extended id number is 0
as per cisco documents  CVR-QSFP-SFP10G  supported with F cards and N7k
I don't see that SFP in the compatibility matrix (linked below), what document says it is compatible ?
https://tmgmatrix.cisco.com/?si=N7K-F312FQ-25
Hi Georg,
