How to configure sw1 and sw2 with different yellow alarm threshold, they are stack together
anitaleung2019
Hi cisco Expert,
there are two cisco 3850X are stacked together. I would like to set the different temperature threshold of yellow alarm. Account to cisco portal, there is one global command to adjust the temperature as below:
system env temperature threshold yellow 18
how to config the yellow alarm is 26 degree Celsius in sw1, yellow alarm is 28 degree Celsius in sw2.
Anita
Hello Anita,
my  experience is that I can SSH to the master switch, but then to be able to access a member switch the telnet protocol has to be allowed inbound on all vtys or I get a connection refused.
So my understanding is that the session switch x is actually a telnet session from master switch to member switch.
Hope to help
Giuseppe
6 Replies 6
can you enter that same global command after accessing the CLI of the individual stack member. e.g.:
StackMaster#session switch 1
This should get you to the CLI of member 1. From there, you should be able to enter global configuration mode and issue the command:
system env temperature threshold yellow 26
I ssh to cisco 3850, I find that the "session" command is invalid. is it related to the IOS version?
Anita
Which IOS version are you running ?
What is the output of 'show switch' ?
Hello Anita,
if you have under line vty 0 15
transport input ssh
You will not be able to connect to  member switch.
I have discovered that the session command uses only  telnet protocol.
To be able to access a member switch I had to do the following
line vty 0 15
transport input ssh telnet
This way I was able to connect to a member switch in a C3850 stack.
However, I am afraid it is not possible to configure different thresholds on different members.
Hope to help
Giuseppe
Dear Giuseppe,
does it means that I need to use telnet service for accessing cisco 3850x switch?
Anita
Hello Anita,
Hope to help
Giuseppe
