daisy chain question. Urgent
jcastanos
hi,
A simple questión..
I need to connect, by a wiring problem, 17 switch in daisy chain.
I have seen that you can configure MSTP  with 20 jumps. Besides STP and latency ,Is there any additional limitation ?. The connection of the switch will be to 1Gb fiber and design is ring.
Has anyone connected so many switch?
Sorry my bad english
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you switches support it, you might look into REP vs. STP.
Depending on your traffic, transit switch links might be more likely to become bottlenecks.
ahmedshoaib
Level 4
Level 4
Hi;
As per Cisco best design & recommendation you need to fallow the hierarchy of Access, Distribution & Core Layer. You can use daisy chain topology also but if you use not recommended topology it will be difficult to troubleshoot (in case of you face of issue) and you cannot utilize the network properly. Unnecessary traffic will be flooded in your daisy chain network topology.
STP or RSTP you cannot use for this network topology MSTP need to verify.
Just take example SW1 is your main switch (Switch become Root Bridge & majority services) are also running, in case if your SW1 having hardware failure of topology change and SW-10 become you STP root which will decide the traffic flow of your network. And your network will be underutilized.
Thanks & Best regards
