01-03-2018 04:47 AM - edited 03-08-2019 01:17 PM
Hello Cisco Experts,
I am quite confused with the configuration of Data and Voice VLAN. VLAN 10 is for data and VLAN 20 is for Voice. My previous colleague has configured two switchs, SW01 & SW02, as follows:
SW01#
interface range GigabitEthernet0/1-47
switchport access vlan 10
switchport trunk native vlan 10
network-policy 1
spanning-tree portfast
spanning-tree bpduguard enable
ip dhcp snooping limit rate 20
interface GigabitEthernet1/1
description uplink
switchport trunk allowed vlan 10,20
switchport mode trunk
ip dhcp snooping trust
SW02#
interface range GigabitEthernet1/0/1-47
switchport voice vlan 20
no logging event link-status
no logging event power-inline-status
no snmp trap link-status
interface GigabitEthernet1/0/48
description Uplink_to_HP_Switch
The Switchs are deployed to different locations.
My question is:
1. whether the switchs are configured correctly. SW01 is in full operation, but no devices are connected to SW02 yet, therefore I could figure it out whether it is also functional.
2. Which switchport mode is currently active on interface range GigabitEthernet0/1-47 to SW01?
My configuration would be following for either switchs and whether it is also correct:
switchport mode access
Switchport voice vlan 20
network-policy 1
description uplink
switchport trunk native vlan10
Switchport nonegotiate
I would be thankful to your reply.
Motiar
01-03-2018 05:50 AM
01-03-2018 06:19 AM
01-03-2018 12:34 PM
Thank you Joseph & Mark for your quick response.
Firstly, by applying the command sh int gx/x switchport I have ascertained that the connected ports on SW01 are access mode, and therefore the pcs are operational (I assume). But to SW02 (if you have a look again), the ports are statically configured as trunk. Therefore, I ask you again, why the end devices like PCs should work to SW02. As I told you, the SW02 is in remote location and no end devices have been connected yet to test.
Secondly, all ports (Gi0/1-47) on SW01 are associated with both data vlan 10 and voice vlan 20. But to SW02, the voice vlan 20 is associated with all the ports, but none of the ports are associated with data vlan10, and all ports are still in default vlan 1 (by applying show vlan brief). Then here is the question again, why the PCs should be working if connect to the SW02, as the ports are not associated with the data vlan? Both of the Switchs are c3560 and the SW02 is configured few weeks ago. Somehow I talked to my ex-colleague and he confirmed me that he testet an IP phone with the SW02.
Please help me to my confusion.
01-03-2018 01:00 PM
