DCI
visitor68
Level 9
Level 9
hello, I have a client who has 3 data centers and wants to connect them and maintain L2 adjacency across them. I know I can do this with ASRs and EoMPLS or VPLS....which Cisco router/switch platforms support EoMPLS and VPLS? I know I can use N7K OTV, too, but that is WAY too expensive.
Reza Sharifi
You can use 6500 with sup-2t
It supports both EoMPLS and VPLS
Thanks, Reza...how about an ISR, like the 2900 or 3900? Is it only ASRs that do EoMPLS and VPLS?
Yes you would ASR
See table-1 for supported platforms
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11_493718.html
thanks, Ill check it out....
