DDNS / TZO
bellaireroad
Hello, I am trying to configure an 1811 for DDNS with TZO.  I have tried CCP which gives an option for TZO address in the drop down box as CGI.TZO.COM
This does not work, so I was going to try and use the CLI.  Question is -  what would the correct address be www.tzo.com or cgi.tzo.com?  thanks
jocovarr
Can you send to us the config snap of the DDNS please?
Do you refer to the line
ip ddns update method test
HTTP
  add http://user:pwd@&myip=
If that's the case I believe the address is
http://cgi.tzo.com/webclient/signedon.html?TZOName=&Email=USERNAME&TZOKey=PASSWORD&IPAddress=
Warm Regards
Thanks for your reply,  I have been working on this since the original post, and still don't have it working.
I contacted tech support at TZO, the commentary is attached as "instructions" As you can see, one of the engineers at TZO has the same router and has it working
I also have attached a copy of the running config
Not sure where to go from here,  Would appreciate any comments on the config or other
Best Regards,
Roger
