Dead ports and ports flapping
I will try to explain as best as I can. I work in a large manufacturing facility. We have about 40 switches throughout the factory and everything is connected with fiber and goes back into a layer 3 switch in our server room, then to a firewall and router which we do not have access too.. (we are working on that, the main facility thinks they should control everything). Anyway our issue has been ports constantly going up and down. Some go up and down as much as 10 times in 2 minutes. It seems very random. Everything is on auto negotiate on both ends.
Today we had a block of ports die completely 09-16 on a 2960s. The switches are pretty old and in very hot and dirty conditions. I have tried shutting the ports down and back up with my laptop plugged in and nothing. Two ports are solid amber with nothing plugged in, one is solid green, and the others have no lights.
I am just wondering if maybe the switches age and conditions the ports are finally dieing on us or if there may be a possible solution. Last week one port was flapping continuously. We switched it to another port on another switch and it stopped so it is not what is at the other end causing it. Any ideas would be very helpful and I can post any show commands you need to see. Thanks
Hello
The above sounds like hardware related.
As for the other ports, What configuration is applied to these ports? - Do you have any port security or and storm control features applied and are these all designated a STP edge ports, (spanning-portfast)
Do you have any high CPU/Memory utilization and does the logging suggest anything?
If applicable can you post the config of one of the effected switches and possibly the interface statistics, logging buffer and cpu/memory stats.
res
Paul
Kind Regards
Paul
NIS-2960S-NORTHMOLDING-0-4#sh run
Building configuration...
Current configuration : 6498 bytes
! Last configuration change at 14:28:37 UTC Thu Jun 8 2017
! NVRAM config last updated at 13:26:44 UTC Thu Jun 8 2017
version 12.2
no service pad
hostname NIS-2960S-NORTHMOLDING-0-4
boot-start-marker
boot-end-marker
enable secret 5 $1$m9.B$wP4Ysk5ijdYrMTPVbX3op1
no aaa new-model
switch 1 provision ws-c2960s-24ps-l
vtp mode transparent
crypto pki trustpoint TP-self-signed-2252581120
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2252581120
 revocation-check none
 rsakeypair TP-self-signed-2252581120
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 200,202-203,211,300
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
 switchport access vlan 211
 switchport mode access
 switchport voice vlan 300
 spanning-tree portfast
interface GigabitEthernet1/0/2
 description NP5 Assembly PLC
interface GigabitEthernet1/0/3
 description NSHAP10
 switchport trunk native vlan 202
 switchport trunk allowed vlan 202,211
 switchport mode trunk
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
 description NSHAP19
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
 switchport trunk native vlan 211
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
 description NP14 PLC
interface GigabitEthernet1/0/15
 speed 10
 duplex full
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 description Trunk to 10.1.2.191 port 1/0/27
interface Vlan1
 no ip address
interface Vlan200
 ip address 10.1.2.193 255.255.255.0
interface Vlan203
 no ip address
ip default-gateway 10.1.2.254
ip http server
ip http secure-server
ip sla enable reaction-alerts
logging 172.24.4.81
snmp-server engineID local 000000090200000AF429C040
snmp-server community private RW
snmp-server community public RO
line con 0
line vty 0 4
 password 7 097F49065857431103
 login
line vty 5 15
 password 7 040B5F274E121E1E1A
 login
ntp clock-period 22519066
ntp server 10.1.2.254
end
bump... tried reloading switch..
Post showed no errors.
There are no err-disable ports either. Switch has been reloaded twice and showing no errors in the post.
