06-09-2017 01:18 AM - edited 03-08-2019 10:55 AM
we have core switch C1 connected to N5k switch T1, in T1, two server with ip 192.168.0.12(connecting to E103/1/12) and 192.168.0.14 (connecting to E103/1/14), these two are fex. and using same access vlan.
both E103/1/12 and E103/1/14 is up up and Mac address is learning in T1 switch.
but in C1, we can only ping 192.168.0.12 but not 192.168.0.14, both these two servers have same gateway. may i know why 192.168.0.14 is not able to reach( we have no access list configured)
06-09-2017 03:18 AM
Hello
Can you ping both server from the 5K T1 switch sourced from the C1 interface?
res
Paul
06-09-2017 06:59 AM
no, 5k can't ping both, only layer 2
06-09-2017 01:28 PM
Hello
can the servers ping each other and also thier gateway.
Is ip routing disabled on the C1 switch?
res
paul
06-10-2017 04:06 AM
in T1, two mac is learning.192.168.0.14 mac is learning
but in core switch, sh arp didn't find 192.168.0.14
why mac learning but sh arp not working
06-09-2017 09:11 AM
You've probably already done the following, but just to make sure:
With both servers on same subnet, same switch, and same gateway, and with only 1 working... I can't think of much to check on the switches itself. This sounds more like a server misconfiguration somewhere. Sometimes disabling and enabling the NIC on the workstation/server can resolve connectivity issues.
Edit: Other causes could be bad drivers as well.
