debug ppp negotiation
sarahr202
Level 7
Level 7
Hi every body!
I was reading about PPP which is suite of protocols. One of the protocol is LCP
According to my book, LCp is charged with establishing, maintaining and terminating the link.
Curious , i set up small lab as r1----r2
and use " debug ppp negotiation " on r2 to see what parameters are negotiated as the link is brought up.
Below is the output:
LINK-3-UPDOWN: Interface Serial0, changed state to up
Se0 PPP: Treating connection as a dedicated line
Se0 PPP: Phase is ESTABLISHING, Active Open
Se0 LCP: O CONFREQ [Closed] id 90 len 15
Se0 LCP: AuthProto CHAP (0x0305C22305)
Se0 LCP: MagicNumber 0x10AF116C (0x050610AF116C)
Se0 LCP: I CONFACK [REQsent] id 90 len 15
Se0 LCP: TIMEout: Time 0x33E2CC State ACKrcvd
Se0 LCP: O CONFREQ [ACKrcvd] id 91 len 15
Se0 LCP: I CONFACK [REQsent] id 91 len 15
Se0 LCP: TIMEout: Time 0x33EAC4 State ACKrcvd
Se0 LCP: O CONFREQ [ACKrcvd] id 92 len 15
Se0 LCP: I CONFREQ [REQsent] id 2 len 10
Se0 LCP: MagicNumber 0x000CE809 (0x0506000CE809)
Se0 LCP: O CONFACK [REQsent] id 2 len 10
Se0 LCP: I CONFACK [ACKsent] id 92 len 15
Se0 LCP: State is Open
Se0 PPP: Phase is AUTHENTICATING, by this end
Se0 CHAP: O CHALLENGE id 15 len 28 from "routerB"
Se0 CHAP: I CHALLENGE id 1 len 16 from "RouterA"
Se0 CHAP: Received Challenge but did not negotiate CHAP
Se0 CHAP: I RESPONSE id 15 len 28 from "RouterA"
Se0 CHAP: O SUCCESS id 15 len 4
Se0 PPP: Phase is UP
Se0 IPCP: O CONFREQ [Closed] id 15 len 10
Se0 IPCP: Address 198.198.198.34 (0x0306C6C6C622)
Se0 CDPCP: O CONFREQ [Closed] id 5 len 4
Se0 LCP: I PROTREJ [Open] id 3 len 10 protocol CDPCP (0x820701050004)
Se0 CDPCP: State is Closed
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to up
Se0 PPP: Unsupported or un-negotiated protocol. Link cdp
Se0 PPP: Trying to negotiate NCP for Link cdp
Se0 CDPCP: TIMEout: Time 0x33EEC1 State Closed
Se0 CDPCP: State is Listen
Se0 IPCP: TIMEout: Time 0x33F4E4 State REQsent
Se0 IPCP: O CONFREQ [REQsent] id 16 len 10
routerB#
Se0 IPCP: TIMEout: Time 0x33FE64 State REQsent
Se0 IPCP: O CONFREQ [REQsent] id 17 len 10
routerB#
Se0 IPCP: TIMEout: Time 0x340638 State REQsent
Se0 IPCP: O CONFREQ [REQsent] id 18 len 10
routerB#
routerB#
routerB#
Se0 IPCP: TIMEout: Time 0x340E0C State REQsent
Se0 IPCP: O CONFREQ [REQsent] id 19 len 10
routerB#
routerB#
Se0 CHAP: I CHALLENGE id 2 len 16 from "RouterA"
All i can see magic numbers, which ensures the link is not looped. what others things are negotiated while the link is being established besides the authentication method ?
thanks a lot!
My question is during link link establishing phase, LCP negotiates some parameters , besides some check such as loop detection, what are those parameters? One of the parameter is authentication method but i am just wondering about what are other parameters ?
Hope this link helps:
http://www.tcpipguide.com/free/t_PPPLinkControlProtocolLCPFrameFormats.htm
__
Edison.
5 Replies 5
Edison Ortiz
username and password?
__
Edison.
Thanks a lot Edison!
I believe user name and password are exchanged in authentication phase which follows the link establishment phase. I might be wrong but that is what the book shows.
Sarah,
You are right, I guess I didn't understand your question.
You asked 'what other things are negotiated' and other than the authentication method, that will be the credentials.
What exactly are you looking for?
__
Edison.
Thanks a lot Edison for being so patient with me.
I was reading about ppp prtocol suite. One of the protocol is LCP. My book says LCP job is to establish and terminate link. Book also mentions that before Lcp establishes a link, it negotiates some parameters , perform some checks such as loop detection etc.
Book shows a illustration which makes me feel during link establishing phase, lcp also negotiates which authentication method the ppp peer will use.After the link is established, authentication phase begins.
Thanks a lot!
__
Edison.
