Default consumption on POE port
sebr
Hello
Due to a recent problem I had to manually configure a POE port.
But I would like to put on a port the default configuration I can not find the command. In the screenshot below I would like to put port 11 on No.
For the configuration I used the following commands, but I do not see how to reset by default.
Thank you
balaji.bandi
Not sure what Switch and Device is this.
In general you can default the interface config as below
config t
default interface fast 0/11
end
and try
show run interface fast 0/11
BB
sebr
I forgot the orders:
1. enable
2. configure terminal
3. no cdp run
4. interface interface-id
5. power inline consumption wattage
6. end
7. show power inline consumption
8. copy running-config startup-config
balaji.bandi
config t
end
and try
BB
I did not specify the model sorry it's a Catalyst 2960-POE.
Thank you for the order is perfect.
