Default-gateway in switch
muraripadhan
Level 3
Level 3
I have 5 vlans
In core vlans are
vlan 10 (192.168.1.1/24) for Management Switch
Vlan20 (172.16.1.1/16) for  Sales
Vlan30(172.17.1.1/16) for HR
Vlan 40 (172.18.1.1/16) for IT
Vlan 50 (172.19.1.1/16) for  Account
and
I have 20 access layer switch
Then what will be my default-gateway in my access switch
Julio E. Moisa
I agree with Joseph, it should be for all the switches:
ip default-gateway 192.168.1.1
You can implement just one default gateway and it should be the default gateway of the management vlan.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
It would be the gateway IP for the switch's management IP.
Julio E. Moisa
To throw a wrench into this...
What happens when you use/connect the management port, to a separate OOB mgt switch?
Do you move the management ip, from the Mgt SVI, to the management interface? There's a default vrf there, so do you need to now enable ip routing? Default gateway or default static vrf route?
