Default Gateway on my 2950
joeadiutori
Hi All,
How do I determine the default GW of my switch?  I type "sh run" and it shows the IP address but not the default GW.  How do I get this information?
Thank You - Joe
2 Accepted Solutions
Reza Sharifi
If you have defined a default-gateway, it will show in your running config (sh run).  You may not have defined it.
cadet alain
by default it is not configured and if you don't see it in the sh run output then it was not configured.
To configure it you must enter global config command: ip default-gateway x.x.x.x
Then sh run | i default-gateway  to verify
Regards.
Alain
Reza Sharifi
I think you must be correct.  Thank You.
Thanks for the rating.
have a look at this link.  If you have a default gateway, it will be in your config (close to the end).
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swipaddr.html#wp1040113
cadet alain
Regards.
Alain
