Default Interface Config
jonhill
Level 3
Level 3
Is there a way of changing the config of an interface or range of interfaces back to there default configuration without having to work through all the commands and negateing them?
The switches we use are 2950, 2960, 2970, 3750 and 6500.
Giuseppe Larosa
Hello Jon,
you can use
default interface type x/y
default interface range ....
from global config
Hope to help
Giuseppe
Giuseppe Larosa
Hello Jon,
you can use
from global config
Hope to help
Giuseppe
