default IP address
thaar_altaiey
Level 2
Level 2
hi
what is the default ip address on cisco switch 4500 and cisco router 2600
best regards
thaar
spremkumar
Level 11
Level 11
AFAIK it doesnt come up with any ip address,you need to configure the same once you populate the boxes with the cards based on the requirement.
regds
guruprasadr
Level 11
Level 11
HI Thaar, [Pls Rate if HELPS]
Any Network Equipment by default will have Class C Addres: 192.168.0.1 as the Management IP Address.
>> But CISCO BOX doesn't come-up with any pre-defined IP @ Address.
Nevertheless, you can CONSOLE to the Switch / Router to assign the necessary IP Address you required for Management.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
I think that we need to be careful in answering the question from thaar. We should differentiate the behavior of IOS (which as noted in previous posts is that there is not a default address) from the behavior of SDM (which does configure a default address). So from the perspective of thaar and other users if their device came with SDM then it will have a default address but if it came without SDM then there is not a default address. So we need to be careful about the environment of the device as we attempt to answer the question.
Rick
Rick
