03-14-2016 01:25 AM - edited 03-08-2019 04:57 AM
I have EIGRP, I need distribution default route.
It's working:
router eigrp 1
redistribute static metric 1000 100 255 1 1500
ip route 0.0.0.0 0.0.0.0 10.10.10.10
But I need using route-map for set different metrics for static routes
It isn't working:
router eigrp 1
redistribute static metric 1000 100 2 route-map ALL
route-map ALL permit 10
match ip address prefix-list DefRoute
ip prefix-list DefRoute seq 5 permit 0.0.0.0/0
What to do?
03-14-2016 07:16 AM
Hello Maxim,
I tested this on my test jig.
The basics are correct but you have a typo in redist route map
You must match the route map name exactly including the case
Your route map
route-map All permit 10 (NOTE All)
so make sure you use
router eigrp 1
redistribute static metric 1000 100 2 .... route-map All
Alex
03-14-2016 07:48 AM
sorry, I made a mistake when typed.
