Showing results forĀ
Search instead forĀ
Did you mean:Ā
2960-X Twinax Compatibilty
nicolasvogel
Dear Support Community,
I'm trying to connect a Core Switch 3850-12XS (running 03.07.03E) with an Access Switch 2960-X (running 15.2(2)E3) using a Twinax Cable CDE2-SFP-1WCX=. Unfortunately the Cable seems to be not Compliant with the 2060-X Uplink Ports (Te1/0/1 and Te1/0/2) --> "%GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Te1/0/1 has bad crc"...
But on the 3850-12XS Switch it's recognized and the Port seems to be good.
Is this Twinax Cable generally not Compliant with 2960-X switches or is it only a Firmware issue?
What is the difference with the SFP-H10GB-CU1M Twinax Cable?
Thank you for your feedback,
Kind Regards,
Nicolas.
Mark Malone
sfp+ is only available on certain platforms of 2960s , what model you on ?
SFP and SFP+ Module Slots
The switch has either two or four 1-Gigabit SFP or two 10-Gigabit SFP+ module slots. The slots marked SFP+ support both SFP and SFP+ modules. The SFP slots support only the SFP modules.
Table 2 Supported SFP Modules for the Catalyst 2960-X Switches
Switch Models
Catalyst 2960X-48FPD-L
Catalyst 2960X-48LPD-L
Catalyst 2960X-24PD-L
Catalyst 2960X-48TD-L
Catalyst 2960X-24TD-L
GLC-BX-D=, GLC-BX-U=, GLC-GE-100FX=, GLC-LH-SMD=, GLC-SX-MMD=, GLC-EX-SMD=, GLC-ZX-SMD=, GLC-T=, GLC-LH-SM=, GLC-SX-MM=, GLC-ZX-SM=, CWDM-SFP-1470=, CWDM-SFP-1490=, CWDM-SFP-1510=, CWDM-SFP-1530=, CWDM-SFP-1550=, CWDM-SFP-1570=, CWDM-SFP-1590=, CWDM-SFP-1610=, SFP-10G-LR=, SFP-10G-SR=, SFP-10G-LRM=, SFP-10G-ER=, SFP-10G-LRM-SM=, SFP-H10GB-CU1M=, SFP-H10GB-CU1-5M=, SFP-H10GB-CU2M=, SFP-H10GB-CU2-5M=, SFP-H10GB-CU3M=, SFP-H10GB-CU5M=
Catalyst 2960X-48FPS-L
Catalyst 2960X-48LPS-L
Catalyst 2960X-24PS-L
Catalyst 2960X-48TS-L
Catalyst 2960X-24TS-L
GLC-BX-D=, GLC-BX-U=, GLC-GE-100FX=, GLC-LH-SMD=, GLC-SX-MMD=, GLC-EX-SMD=, GLC-ZX-SMD=, GLC-T=, GLC-LH-SM=, GLC-SX-MM=, GLC-ZX-SM=, CWDM-SFP-1470=, CWDM-SFP-1490=, CWDM-SFP-1510=, CWDM-SFP-1530=, CWDM-SFP-1550=, CWDM-SFP-1570=, CWDM-SFP-1590=, CWDM-SFP-1610=.
Catalyst 2960X-48TS-LL
Catalyst 2960X-24TS-LL
GLC-GE-100FX=, GLC-LH-SM=, GLC-SX-MM=,
GLC-LH-SMD=, GLC-SX-MMD=, GLC-EX-SMD=, GLC-T=, GLC-TE=, GLC-EX-SMD=.
Hi Mark,
Thank you for your response.
So if I understand you mean that I have to order a SFP-H10GB-CU1M= instead of my CDE2-SFP-1WCX= is that right?
Hi Heres the full matrix you can see what will work on both switches just search your platform like 3850 or 2960 and it show them , SFP-H10GB-CU1M=,  this should work on both of them but you have other options as well I don't see that other CDE
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
