Default route through DMVPN And OSPF
Blason R
Hi Guys,
I have topology like this and would like to achieve default gateway pointed towards hub location through Spoke 2 [RS3] where I have two MPLS links terminated.
Rest everything is working fine where I have MPLS and one ISP but not sure about two MPLS. I am pretty novice to Dynamic Routing concepts hence would really appreciate if someone can help here!!
TIA
hard to say without seeing the OSPF configurations of RHU and RS3, can you post those ?
Basically, on RS3 you could configure different OSPF costs for each tunnel (ip ospf cost), and on RHU, configure the 'default-information originate always metric' command to send the default route to RS3.
Either way, post the configurations of both routers, that will make it easier to figure this out...
