default route
saidfrh
Is it possible for router B with two serial interfaces be configured with two default routes? The above router is connected to routers A and C. No routing protocol is configured, except for initial default routes.
Router B
s0 193.168.50.1/30
s1 193.168.50.5/30
Router A
s0 193.168.50.2/30
Router C
s0 193.168.50.6/30
dnewell24
Yes, it is possible. Set the next hop as the physical interface and I believe this will provide redundant load balancing configuration. If Router A or C shutdown or loss the serial connection router B will remove the router for the route table.
desai.jaideep
Level 5
Level 5
The simplest way is to configure RIP on all the routers.
JD
dnewell24
Thanks. How do I check mark this to indicate resolved?
