FastEthernet Interface
maryodriscoll
Level 3
Level 3
Can someone tell me why a fastethernet interface will show a status of up down even when there is nothing plugged in ?
m.sir
Level 11
Level 11
Ethernet interface can be up, down or administratively down - (interface is administratively down when command shut is entered)
The interface is up if the HW has been activated - this is HW test not integrity test - the interface can be up even if no cable is attached
You can check status of interface with command
show interface fastethernet
M.
Rate helpful posts
m.sir
Level 11
Level 11
M.
Rate helpful posts
