Default VLANs 1002-1005
omni-jburk
I have a used Catalyst 3650, and I am attempting to change the the unused VLANs' state to suspend. Unfortunately I get the following return message:
%Default VLAN 1002 may not have its operational state changed.
Current VLAN configuration:
#show vlan
VLAN Name                             Status    Ports
1    default                          active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Is it possible to suspend them with a different command so that I can close the unused VLANs, or is this older model not capable of doing so?
Thank you in advance.
2 Accepted Solutions
Those vlans are legacy vlans and you would not be able to use them even if you wanted to ie. the act/unsup part where unsup mean unsupported.
So you are fine to leave them as is.
Jon
You do not need to worry those VLAN (100X range one), they no Longer work in new Lan Segment.
BB
5 Replies 5
balaji.bandi
Those are extended VLAN and reserved, they will be default VLAN,
this will not going to effect anything with standard setup ?
what you mean suspend ?
BB
We do not use those VLANs, and have no purpose that I am aware of, so we just wanted to suspend them so that our vulnerability scanners do not show them as open.  There are other VLANs that I removed from the lines for privacy reasons that we do use, but if you believe it will cause a conflict we can leave 1002-1005 open.
Jon
BB
Thank you both for the explanation, I will use them as my request for risk acceptance..
