Defining traffic flow
Jesse Hottle
Level 4
Level 4
I have a 7206 with 2x FE100 interfaces. I am looking for a way to define within the router IOS how to define which interface defined subnets pass traffic over.
For example I have FE1/0 connect to a LAN, I have 192.168.1.0/24 connected to this segment. On FE2/0 I have another LAN, 192.168.2/0/24 connected to this segment. I need to be able route all traffic LAN and WAN traffic for segment one, only on FE1/0 and vise versa on segment 2. Can I do this with an ACL applied seperatly to each interface? Also, how can I define a default route (0.0.0.0 0.0.0.0 192.168.1.x) or (0.0.0.0 0.0.0.0 192.168.2.x). I have two sperate networks, all internet users, who will need to get out. Each of these interface are going to routed to different network routers.
Jhottle
mohammedmahmoud
Level 11
Level 11
I guess that you need to do source based routing PBR (Policy Based Routing).
please review these documents and get back if you have further problems:
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
