Delete a directory on a 2950 switch
djgizmo250
I created a directory on the switch, but now I can't delete it. Is there a way to delete a folder?
smothuku
Level 7
Level 7
Hi ,
I think you can use the command "rm dir " to remove particular directory in switch.
satish
smothuku
Level 7
Level 7
Hi ,
satish
Thank you. I've never removed a directory before. :)
