Deleted DNA essential technology package from 9200-l how do I get it back?
peterace1
While learning to register the network-essential  license and figured I didn't need the DNA-essential license, I deleted the DNA essential technology package. I didn't realize there was no need to delete the DNA essential technology package and in fact when I registered with smart license it would have registered both licenses, which is what I did on the other 9200-l switch once I knew how to register via smart licensing
My question is how do I get the DNA essential technology-package to show back up in the switch so I can register that license
The first picture shows the switch where I deleted the DNA essential technology package and the 2nd picture shows the switch with the DNA essential package.
5 Replies 5
Reza Sharifi
Try installing the license again.
license right-to-use activate addon dna-essentials subscription slot switch-ID acceptEULA
Link;
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9300_cg/b_166_sys_mgmt_9300_cg_chapter_011.html#task_bmw_tvj_n1b
I'm running code 16.9.3 and that command is not available
Worked!!
Thanks!
Glad to know it worked.
