ws-c4948 10G I could use some help please.
So I'm brand new to Cisco awesome equipment though. I bought a switch and when I first booted it up it was stuck in a boot-loop. So I researched and read and through trial and error I got it unstuck and the correct image in place. So I am configuring the switch have not done a tftp server yet and follow a wrong procedure and assign the wrong ip address to the switch I was supposed to be doing a loop-back. So I figured I would just start over good practice right. I'm trying to self teach myself Cisco here that should tell you I'm not the brightest crayon in the box. So I  do a clear config all and it works great so great that even though I had supposedly done a running config save I now have no boot image no slot0 image and no boot system flash bootflash image. I did however make me a tftp server with tftp64 but cant for the life of me get the command right for Rommon to drop me an image. Hell at one point I could see on a reset it said boot  booted from 0x010 cat4500-entservicesk9-mz.150-2.SG10.bin it was right there just not in the right position I have been driving myself crazy here could someone please throw me in the right direction?
Rom Monitor Program Version 12.2(31r)SGA4
Supervisor: WS-C4948 Chassis: WS-C4948
Hardware Revisions - Board: 6.0 CPLD: 4 Dagobah: 225
MAC Address : 00-15-c6-de-ef-ff
IP Address : 192.168.0.69
Netmask : 255.255.255.0
Gateway : 192.168.0.1
TftpServer : 192.168.0.6
Main Memory : 256 MBytes
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Established physical link 100MB Full Duplex
Network layer connectivity may take a few seconds
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
rommon 1 >
That config-register value is wrong.
Plus, delete the ROMMON file "delete /f /r bootflash:cat4500-ios-promupgrade-122_31r_SGA4".
32 Replies 32
Leo Laohoo
Post the complete output to the command "dir flash:".
Tftp session failed: File not found
rommon 4 >dir flash
The device has either been removed or bad device name flash
usage: dir { [ bootflash: ] | [ slot0: ] }
rommon 5 >dir bootflash
The device has either been removed or bad device name bootflash
rommon 6 >dir slot0
The device has either been removed or bad device name slot0
rommon 7 >
The syntax is incorrect. It should be: dir flash:
NOTE: Please observe there is a ":" at the end of "flash:".
If "dir flash:" doesn't work, then try "dir bootflash:".
rommon 1 >dir flash:
The device has either been removed or bad device name flash:
rommon 2 >dir bootflasdh:
The device has either been removed or bad device name bootflasdh:
rommon 3 >
rommon 1 >dir bootflash:
File size Checksum File name
424748 bytes (0x67b2c) 0xc3774860 cat4500-ios-promupgrade-122_31r_SGA4
19476896 bytes (0x12931a0) 0xcbb5b23 cat4500-entservicesk9-mz.150-2.SG10.b
in
1202 bytes (0x4b2) 0xd042fd48 post-2000.01.01.00.00.04-failed.txt
1202 bytes (0x4b2) 0xb550ef8d post-2000.01.01.00.02.38-failed.txt
1202 bytes (0x4b2) 0xb4896642 post-2000.01.01.00.05.12-failed.txt
1202 bytes (0x4b2) 0xe450c548 post-2000.01.01.00.09.16-passed.txt
1202 bytes (0x4b2) 0x7030949 post-2000.01.01.00.11.50-failed.txt
Total space = 60817408 bytes, Available = 40908848 bytes
onitor: command "in" not found
rommon 9 >1202 bytes (0x4b2) 0xd042fd48 post-2000.01.01.00.00.04-failed.
txt
monitor: command "1202" not found
rommon 10 >1202 bytes (0x4b2) 0xb550ef8d post-2000.01.01.00.02.38-failed
.txt
rommon 11 > 1202 bytes (0x4b2) 0xb4896642 post-2000.01.01.00.05.12-
failed.txt
rommon 12 > 1202 bytes (0x4b2) 0xe450c548 post-2000.01.01.00.09.16-
passed.txt
rommon 13 > 1202 bytes (0x4b2) 0x7030949 post-2000.01.01.00.11.50-f
ailed.txt
rommon 13 >
rommon 14 > Total space = 60817408 bytes, Available = 40908848 bytes
monitor: command "Total" not found
rommon 15 >
in
My boot image is there
Try the command "boot bootflash:cat4500-entservicesk9-mz.150-2.SG10.bin".
Not sure what was different because I swear I ran that exact command a hundred times but there it is and its back up. Feel like a mental midget at the moment but hey thank you very much.
Mar 1 00:00:02.303: %C4K_IOSSYS-3-BLANKSTARTUPCONFIG: Blank or invalid startup
-config, booting up with defaults
*Jan 1 00:00:20.807: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for typ
e vlan
*Jan 1 00:00:23.663: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuratio
n is ignored based on the configuration register setting.
*Jan 1 00:00:23.875: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4948 S/N:
FOX084307L3 Hw: 1.2) is online
*Jan 1 00:00:24.171: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M),
Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 07-Apr-15 09:46 by prod_rel_team
*Jan 1 00:00:25.463: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/45: New trans
ceiver (speed 10Gbps) is incompatible with this module
*Jan 1 00:00:25.499: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/46: New trans
*Jan 1 00:00:25.559: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/47: New trans
*Jan 1 00:00:25.647: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/48: New trans
And I take it my 10 G ports aren't configured correctly or just have the wrong hardware?
                    >... wrong hardware
 If you are talking about transceiver check this link for compatibility info's : https://tmgmatrix.cisco.com/?npid=528
 If you are using 3rd party transceivers you may want to configure :
             service unsupported-transceiver
             no errdisable detect cause gbic-invalid
 M.
post the output of "sho inventory"
it seems like this is just a 4948, not a 4948-10g. The reason I say that is that the 4948 has port 1-44 as the RJ ports, and 45-48 are either the RJ of SFP. A 4948-10g has 48 RJ ports and two 10gig (X2 transceivers if I remember correctly) slots.
 - Please post the output of show module
    M.
ok will get to module in a sevc looks like switch was reconfiguring itself while I was at work today
config-register = 0x142
Chassis Type : WS-C4948C4K_IOSSYS-3-BLANKSTARTUPCONFIG: Blank or invalid startup
Power consumed by backplane : 0 WattsENDED_SYSID: Extended SysId enabled for typ
e vlan
Mod Ports Card Type Model Serial No.io
1 48 1000BaseX (SFP) Supervisor WS-C4948 FOX084307L3
M MAC addresses Hw Fw Sw Status
1 0015.c6de.efc0 to 0015.c6de.efef 1.2 12.2(31r)SGA 15.0(2)SG10 Ok
Switch>ht (c) 1986-2015 by Cisco Systems, Inc.
*Jan 1 14:35:03.483: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/45: New trans
*Jan 1 14:35:03.523: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/46: New trans
*Jan 1 14:35:03.595: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/47: New trans
*Jan 1 14:35:03.671: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/48: New trans
rommon 1 >
dir bootflash:
in
IF in ROMMON (look at the prompt), do the following
delete bootflash:at4500-ios-promupgrade-122_31r_SGA4
Who's actually playing with the switch?  I can see the config-register changing from 0x2102 to 0x2142.
