Deleteing files and directorys
manuel.dennis
I have loaded an IOS update to a Cisco 3560 switch.  After loading and cleanup I have a directory left over from the old IOS that causes me problems, but I can't delete it or the sub directory or file in it.   Any suggestions would be appreciated.  Shown below is from the CLI.  c3560-ipservicesk9-mz.122-58.SE2.bin is the current IOS.  Ignore the file dates.  I had to do a password restore and load system defaults because the previous SA left a mess behind when he left.
Manny
Switch#dir flash:
Directory of flash:/
    2  -rwx         616   Mar 1 1993 00:31:12 +00:00  vlan.dat
    3  -rwx    15965969   Mar 1 1993 00:50:21 +00:00  c3560-ipservicesk9-mz.122-58.SE2.bin
    4  -rwx        3096   Mar 1 1993 00:03:01 +00:00  multiple-fs
    5  -rwx        1919   Mar 1 1993 00:03:06 +00:00  private-config.text
    6  drwx         128   Mar 1 1993 00:21:40 +00:00  c3560-ipservices-mz.122-35.SE5
  464  -rwx        2573   Mar 1 1993 00:03:06 +00:00  config.text
32514048 bytes total (14361600 bytes free)
Switch#dir flash:/c3560-ipservices-mz.122-35.SE5
Directory of flash:/c3560-ipservices-mz.122-35.SE5/
    8  drwx        4160   Mar 1 1993 00:09:15 +00:00  html
  463  -rwx         440   Mar 1 1993 00:09:52 +00:00  info
Switch#del /force flash:/c3560-ipservices-mz.122-35.SE5:info
%Error deleting flash:/c3560-ipservices-mz.122-35.SE5:info (No such file or directory)
Switch#delete /force flash:c3560-ipservices-mz.122-35.SE5
%Error deleting flash:c3560-ipservices-mz.122-35.SE5 (Is a directory)
Somasundaram Jayaraman
Can you try the below command
delete /force/recursive flash:/c3560-ipservices-mz.122-35.SE5/c3560-ipservices-mz.122-35.SE5.bin
Hope this helps
Cheers
Somu
Rate helpful posts
Hope this helps
Cheers
Somu
Rate helpful posts
BINGO!!!!!!
worked like a champ!
Saw it first , so I didn't get a chance to try del /force flash:/ c3560-ipservices-mz.122-35.SE5/info.  It may have worked too, but no way I'm going backwards to find out.
Thanks for the help.
Manny
cadet alain
it should be
If somu command doesn't work then delete both files in the directory this way then delete the empty directory and it should work.
Regards.
Alain.
